large and medium formate
Discussion in 'Beyond the Basics' started by hot shot, Mar 25, 2006.
  1. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    whats the benifits of medium and large formate over stander 35mm or digital
    also whats the diffrence between large and medium formate cheers
  2. ThomThomsk
    ThomThomsk TPF Noob!
    Oct 27, 2005
    441
    50º north
    Size, which does matter after all...
    Medium format negatives start at 6x4.5 centimetres (actually it's a bit less than that), which gives you 2.5 times as much area as 35mm. Using 120 roll film, which is 6 centimetres wide, there are a lot of 6x6 and 6x7 format cameras out there, and you can get 6x8 and 6x9. That is a LOT of negative, and usually a lot more detail than 35mm.
    Large format is even bigger. The negative sizes here tend to be given in inches, so 4x5 is at the smaller end, with other common sizes being 5x7 and 8x10. If you thought medium format gave you a lot of detail on your negative, that's nothing compared to LF, which I've only read about but which I'm told can be absolutely stunning.
    Then there is ultra large format. Ilford made a batch of special order sheet film earlier this year in sizes up to 20x24 inches. I can only imagine the size of camera, but think of the information you could get in such a huge negative.
    Thomsk
  3. Hertz van Rental
    Hertz van Rental We're supposed to post photos?
    Nov 8, 2004
    16,738
    46
    Where am I now?
    It's not just a matter of the quality of the neg/tranny produced.
    Larger format cameras have much larger viewfinders which means that the image you see is also much bigger. You can see far more of what is going on.
    With large format (5x4 and above) you can actually go over the ground glass viewing screen with a magnifier to check spot focus.
    Large format (and some medium format within limits) give you camera movements to which allow you to control the plane of focus, correct converging verticals, shoot into mirrors without getting a reflection (I love that one) and to distort shapes a little.
  4. ThomThomsk
    Oct 27, 2005
    441
    50º north
    After 20+ years of shooting 35mm, I got my first medium format camera a week ago. It's only a 645, but you are quite right - the viewfinder is amazing.
    Even so, I can see the day coming when I'll need to go to 6x7 and then to LF. There is a guy over on APUG whose signature line is "Did I mention that 5x4 looks small today?". Which it probably does.
    Thomsk
  5. stingray
    stingray TPF Noob!
    Oct 28, 2005
    179
    Care to explain Hertz?
  6. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    so what are the diffrences between a tipical digital camera lets say for explinationporposes a canno 350d @ 8 million pixles and standard (nothing top of the rage) medium format camera
    Thanks for your help
  7. DestinDave
    DestinDave Master of Non Sequitur
    Jan 29, 2006
    480
    Not where I thought I'd end up
    The way it's been explained to me is with a digital camera let's say you have 8 megapixels. That's 8 million "pieces" of information for that picture. With a medium format negative (or transparency) if you were able to count all the grains of silver on the emulsion you would probably be in the tens of billions! So, in effect the difference is 8 megalixels -vs- 10 gigapixels...
  8. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    ok then so whats the diffrence between a medium format camera with a digital back on it and a 8 million pixle digital camera??
    this is starting to to get complicated sorry
  9. bigfatbadger
    bigfatbadger TPF Noob!
    Mar 19, 2006
    464
    Nottingham, UK
    The cost!
  10. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    thought that would be the case lol
  11. hot shot
    hot shot TPF Noob!
    Dec 29, 2005
    496
    so would it be worth getting a medium format camera?
    thats probably a realy stupid question
    cheers
  12. DestinDave
    Jan 29, 2006
    480
    Even then, I don't think you'd get the quality enlargements from a MF digital as you would from a MF slow ISO film. I may be wrong (certainly not a pro at this) but even with MF digital pixel size limits clear enlargements to 16x20 or 20x24 before you start seeing "grain" or "noise". And, the last time I heard I think a digital back for a Mamiya 645 was something $10K - a Hassie back in the $15K range.
    Like I said - I may be wrong so please correct me if this is bad info...
