Lens Hoods?
Discussion in 'Photographic Discussions' started by j8kkb, Mar 18, 2010.
  1. j8kkb
    j8kkb TPF Noob!
    Mar 10, 2010
    10
    UK Essex
    Does anybody shoot with these on all the time when out on locations if so why? reason is all my lenses have hoods but take up so much room in the bag unless I take them off ...and putting them back on I tend to leave them off again ...may mean the difference between a big bag and one that is nice and neat.
    cheers
    Jak
  2. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I usually have my hood on my lens. I find them good protection for the lens (in case you clip the corner on something) and they don't put an extra layer of glass between my optics and my subject.
  3. j8kkb
    j8kkb TPF Noob!
    Mar 10, 2010
    10
    UK Essex
    I never thought of it like that ....pretty good reason and cheaper to
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    always, inside outside, always.
    they reduce flair if not avoid it all together unless one is shooting directly into the sun.
    a nice by product is the protection value mentioned above.
  5. KmH
    Apr 9, 2009
    40,337
    5,508
    Iowa
    In addition to the front lens element safety buffer zone they provide, using the lens hood also improves contrast and helps prevent lens flare when you have a bright light source near the lens axis.
  6. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I don't use "protective" filters either, but always take time to put the hood on. I formed a small compartment in MY BAG just for hoods because it was a PITA having them on the lens in the bag.
  7. Josh66
    Oct 31, 2007
    14,604
    1,238
    Cedar Hill, Texas
    Unless I just don't have a hood for that lens, it's always on.
  8. iAstonish
    iAstonish TPF Noob!
    Feb 12, 2010
    270
    Just flip the hook backwards and leave it on your lens if you need a little more room. That way, they're already on the right lens when you're ready to use it too.
  9. KmH
    Apr 9, 2009
    40,337
    5,508
    Iowa
    I was going to mention that too. Most hoods can be put on the lens facing the other way.
    [​IMG]
  10. Hamtastic
    Hamtastic TPF Noob!
    Mar 9, 2010
    87
    USA
    I use a lens hood for every shot, unless the camera just doesn't have one (like my digital compact and some of my vintage cams). I have had a lot of experiences where I think it has protected the lens as mentioned above. Beyond that I believe the lenses are designed to be used with the hoods. The hoods come off to make the whole lens more compact for storage, not because it's an optional feature. Flaring can be very subtle, and may not be easily visible, but it can wash out colors and reduce contrast. I look at a lens hood like a seat belt: I don't expect to have problems, but if I do the lens hood is on. I decided to use them every time a long time ago, and today it's just habit to put one on. I don't even think about it.
  11. jchin
    jchin TPF Noob!
    Mar 19, 2010
    9
    New York City
    For me ... the lens hood is cheap protection for my lens (kids fingers, etc.).
    However, I do use it to prevent glare.
  12. Frank_Irwin
    Frank_Irwin TPF Noob!
    Mar 19, 2010
    Wirral, UK
    The lens hood is purely there to avoid/minimise reflections from the sun. Unless you are taking photographs with the sun directly behind, you will need to use the hood. It is not just the sun directly into the lens, but also reflections from shiny objects such as shop windows to the side (Mirror law: Angle of incidence = angle of reflection)
