Light C&C
Discussion in 'People Photography' started by Laika, Mar 22, 2010.
  1. Laika
    Laika TPF Noob!
    Feb 19, 2008
    165
    Ohio
    Any critique on this picture? What could I have done differently? Does the mood here work?
    [​IMG]
  2. Mesoam
    Mesoam TPF Noob!
    Sep 10, 2007
    1,120
    4
    CT
    is the girl edited into the shot? how much post processing?
  3. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    Mood works beautifully here. The only thing I'd do is clone out that green flare to her right as it is pretty distracting...almost looks like she is looking at it.
    White dress looks overexposed to me, but then again....nearly everything looks overexposed on my work monitor....so I can't say for sure on that.
    On second glance...is the real or was she pasted into this scene. It actually looks like she was pasted in since she is so bright yet her surroundings are so dark. If this were real, the ground should be better lit in front of her creating some type of shadow of her behind (since there are shadows all over). There should be a shadow of her or no shadows at all based on the lighting that should have taken place to get her lit so well.
  4. Laika
    Laika TPF Noob!
    Feb 19, 2008
    165
    Ohio
    She was indeed really at the location. Though in editing I did select her and brighten her up, since I wanted a lot of contrast between her in the background.
    Her dress is not over-exposed on my monitor, as I can make out the polka dots on her dress.
    I also hate the blue dot. Though I am having trouble removing it. Should I just clone it out or try to change the color?
  5. mwcfarms
    mwcfarms No longer a newbie, moving up!
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Great picture. Agree about the green dot though.
  6. PerfectlyFlawed
    PerfectlyFlawed TPF Noob!
    Feb 2, 2010
    2,408
    19
    Tempe, Arizona
    Love the shot.. however, the girl looks photoshoped or something.. like she was inserted into the picture.
  7. ocular
    ocular TPF Noob!
    Jul 29, 2009
    1,107
    outoftown
    What did you do ? Brush her with white and set a blending mode, and then erase the edges ? She does look like she's been pasted into the scene. There's that cut out effect if you zoom in around her shoulders, not saying u did that though. My suggestion to clean it up, would be #1 remove green flare/light. #2 clean up the white around her shoulders with a soft brush.
  8. NateS
    NateS TPF Noob!
    Sep 27, 2007
    2,753
    40
    Missouri
    Upon reviewing it again on a better computer, her dress is exposed fine (as I suspected). However, this edit really ruins it for me. She is well lit and bright, well exposed, etc.... however the ground all around her isn't. If this was lit properly to get the same result (could have been done) then the area around her feet should be better lit and there would be a shadow of her on the ground which would have helped by adding depth. As it sits now it looks as if she was photoshopped in (whether she was or not) and I would lighten the foreground/background area (maybe try a graduated filter in your editor) to make her not stand out so bad.
