Light meter?
Discussion in 'The Lensbabies Place' started by crawdaddio, Jun 13, 2006.
  1. crawdaddio
    crawdaddio TPF Noob!
    Dec 5, 2005
    1,157
    14
    Central IL
    Will my light meter work with these? I have a nikon D50 and N80 35mm. The website says that the LB will not communicate electronically with your camera. So I can live without AF and obviously you set the aperture manually, but most importantly does your meter work? Any one use one with a D50? Please help, I am considering buying one but not if I have to use a handheld meter.
    Thanks in advance,
    ~DC
  2. Unimaxium
    Unimaxium TPF Noob!
    Nov 13, 2004
    2,689
    22
    Northeastern University, originally from Philly
    I think I've heard that the D70 and D50 won't meter when using non-AF lenses (e.g. lensbaby). But I suppose you can always use the sunny-16 rule and bracket a lot (and use the histogram to check). Being digital, you don't really have to worry about wasting shots.
    edit: just realized this thread is kinda old. ah well.
  3. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    It's not non-AF lenses, it's non-CPU lenses (AI). Since they do say that they don't communicate electronically, that would lead me to believe that the Lensbabies are non-CPU lenses.
  4. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    If it doesn't electronically communicate with the camera the lens probably being stopped down when you stop it down. This is in contrast to a normal lens that doesn't actually stop down until you take a picture. Therefore your metering should work just fine since it's reading the amount of light coming in after you stop down.
  5. Tiberius
    Tiberius TPF Noob!
    Jun 19, 2006
    328
    Michigan, USA
    But the D50/D70 won't meter at all without a CPU (electronic communication). The D100/200/2x has no such issue, however.
  6. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Ohhh....
    Then I guess just take a guess and work from there.
