Looking for a lens for macro photography
Discussion in 'Photography Beginners' Forum' started by lkWinnipesaukee, Feb 17, 2007.
  1. lkWinnipesaukee
    lkWinnipesaukee TPF Noob!
    Feb 17, 2007
    173
    Hey guys,
    I'm looking for an EF lens that I can use for close-ups as well as a general lens (I forget the name; it's between wide-angle and tele). Any suggestions?
    I'm only a HS student with a limited budget, so I'd like to keep it on the cheap side.
    Thanks. :wink:
  2. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Are you thinking of the EF50mm f2.5? Cheapest of Canon's Macro lenses and doesn't give 1:1 but still very sharp. Reviews here from 49 users give it 9.3/10!!
    http://www.fredmiranda.com/reviews/showproduct.php?product=45&sort=7&cat=2&page=3
    the 100mm Macro is a better lens but it's pretty expensive in comparison.
    Look also at the Sigma/Tamron Macro lenses. Sigma do a 50mm f2.8 1:1 macro which may interest you also.
    Regards
    Jim
  3. lkWinnipesaukee
    Feb 17, 2007
    173
    Thanks. I'll look into those 50mm lenses.
    Right now for a 50(ish)mm lens I'm using the Helios off my Zenit. Although the Russians make drop-dead reliable guns, they sure as heck don't make decent photography stuff. So yes, I think this lens must come next.
    Thanks for the help.
  4. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    There's a few macro lenses going around
    Sigma 105mm
    Tamron 90mm
    Canon 100mm
    These are the more popular lenses but cost a little more. Get 1:1 lifesize if you can.
    Regards
    Jim
  5. Groupcaptainbonzo
    Groupcaptainbonzo TPF Noob!
    Nov 9, 2006
    463
    Turners Hill, West Sussex, UK.
    Macro lenses come in different sizes for different jobs. If you are shooting in a home studio, you will probably want a 50mm (ish). But for insects (thay scare easily and you can't get so close as you can to a paper clip ! ! !). you will need a longer lens (105 -150 ish). The best advice I can give is to look around and play in your local camera shop. at the moment about the best range is made by Sigma . I have a drop dead georgeous Sigma 105.mm f2.8 EX DG macro. and it is sharper and half the price of the canon... I have just this minute read a review of available 100mm ish macro lenses, the reviewer gives the Tamron 90mm f2.8 Di a really good write up.There are of course plenty of second hand lenses out there, but be careful.
    If you let us know the kit you have now, and what you would like to shoot with it, we can really get into the problem. If you are on a restricted budget you might even try extention rings . or if you want the best then bellows and a 50mm prime are the top answer. It really depends on the set up and the results that you are after
