ghpham
- Joined
- Dec 16, 2007
- Messages
- 532
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
I was just about to say. Tonemapping and HDR (High Dynamic Range) imaging are two completely different aspects. One is nothing more than an method of determining the luminance of a point based on the weighted luminance of surrounding points (tonemapping), and the other is a method of creating an image which has a dynamic range which is too wide for any single sensor to capture.
Both your example Hugo and the OP's are examples of simply using tonemapping. This has nothing to do with HDR, and does not require more than one image. In the case of the OP it doesn't even require creating 3 seperate tweeks of a RAW.
By all means use tonemapping it's a valid way of creating a sensation of micro-contrast around an otherwise dull image. But let's call a spade a spade and not call it an elephant shall we. Simply opening an image in Photomatix and saving it again does not make it a HDR image.
Tonemapping is nothing but a watered down version of HDR. It is so because there is no HDR screen displays availabel that any of us can afford to see the true range. Tweaking an image to give a fantasy like picture is not really the purpose of tonemapping or HDR. One can use it to create a new "style" but I would preferred it not called...HDR.
