Derrel
Mr. Rain Cloud
- Joined
- Jul 23, 2009
- Messages
- 48,225
- Reaction score
- 18,941
- Location
- USA
- Website
- www.pbase.com
- Can others edit my Photos
- Photos OK to edit
Many AF lenses have extremely hair-trigger manual focusing adjustment at distances beyond about 3 to 5 feet; with many AF lenses, a one-millimeter off mis-adjustment of the manual focusing ring can easily lead to a focus point that misses the subject distance by anywhere from a foot to 15 feet. MOST AF lenses have fairly sloppy manual focusing rings, and this makes it tricky to set the distance with precision and accuracy. Additionally, the in-camera viewfinder focusing screen in most D-SLR cameras is very bright, yet slightly low in contrast, and the "scatter" level of the screen's grind makes differentiating in-focus from out-of-focus much more difficult than the type of screens used in manual focus cameras from bygone eras. If you're focusing a lens using LiveView, then manually focusing can be pretty easy, esp. if the camera offers focus peaking. Overall though, for most people, using autofocus, and carefully selecting the AF bracket in use, and aiming it carefully, will lead to good focus most of the time.
Some lenses will be very challenging to focus accurately with high confidence in many situations, while other lenses will be relatively easy to focus manually in most scenarios; slow lenses, like f/3.5~5.6 small zooms like say 28-80mm cheapie, can be a real PITA to focus manually in light that is not very bright. Fast primes like 85mm f/1.4 will focus easily, same with 300mm f/4 lenses. Slow zooms like say the 70-300mm f/4.5~5.6 AF-Nikkor are easier to focus accurately at the long end, but not quite so easy to focus at the shorter end of their zoom.
The decision to focus manually using hand-and-eye is not to be taken lightly; focusing deliberately, but allowing the camera's focus drive motor or the lens's motor to drive the elements to the proper distance is usually the best thing, for most people; the more experience you have, and the more the lens works in your favor and not against you, the better manual focusing is likely to be.
