ND Neutral Density Filter help please!!
Discussion in 'Digital Discussion & Q&A' started by MommyOf4Boys, Jun 26, 2006.
  1. MommyOf4Boys
    MommyOf4Boys TPF Noob!
    Dec 20, 2005
    2,386
    51
    Alabama - just moved here from Texas
    I guess I am doing something wrong! I have seen so many gorgeous photos done with the ND filters. I have the 4x (2 stops) and the 8x (3 stops) filters. I do not know if I am just metering wrong or if I am suppose to take two shots and combine them, which I really do not want to do.
    When I metered the shot, I metered off of the middle tone in the sky and it made the sky come out gorgeous, but the ground areas were extremely dark! When I metered off of the middle tone on the ground the ground really made no change, but the sky was really blown out. I am wanting to use these filters when I go to the beach to get great shots of the sunset as well as a smooth/silky beach.
    If anyone can please point out what I am doing wrong I would soooo much appreciate it!!
  2. DepthAfield
    DepthAfield TPF Noob!
    Feb 24, 2006
    566
    Itchycoo Park
    Perhaps the effect you are looking for would be best attained by using a split neutral density filter, which will stop down the sky while leaving the foreground normal.
    As for sunset/sunrises, give this a try:
    With your camera securely mounted on a tripod, compose your photograph.
    Pan the camera left or right far enough to remove the sun from the viewfinder..
    Meter and set your exposure.
    Pan back to the original composition and take your photo.
    You may want to bracket 1 stop in both directions. This method of metering sunset/sunrises has almost always provided me with a good exposure.
  3. Xmetal
    Xmetal TPF Noob!
    Nov 22, 2004
    2,351
    29
    Newcastle, Australia
    You have 2 options with your dilemma:
    1/2 ND filter - Old school way of doing it because it was created mainly for Film cameras, the idea being so you don't have to do 2 exposures and splice them in the Darkroom. :???: (dunno if that's what they do but you get the idea)
    HDR - New school way of evening out the exposures if you're shooting digital, involves exposure bracketing and shooting upto 8 or 9 of the same image then layering them all together in Photoshop or equivelent program. :)
    I started a HDR thread Here, Digital Matt and Archangel are your gurus in that field. :)
  4. MommyOf4Boys
    Dec 20, 2005
    2,386
    51
    I guess I should mention that these are not the graduated ND filters..they are the full screw on filters.
  5. Arch
    Arch Damn You! Staff Member Supporting Member
    Jan 21, 2006
    8,487
    102
    locked in the attic
    mommy..... the way i do it is, to either merge two shots....... merge the same shot processed differently - for sky and forground or...... (and this one may be useful seeing as tho you dont want to have to merge).... I simply expose mainly for the sky.....(shot in RAW) but dont let the forground go TOO dark.... so midpoint sky...... then when you bring it into ps, use the shadow/highlight command.
    Between the RAW conversion and the shadow/highlight, you should be able to get a decent exposure from the one shot.
    If not..... a slight variation, (and this is easier than using two exposures too)... is to immediately duplicate your layer when first in ps....... then use shadow/high on one layer for the sky...... and for the forground on the other, then layer mask the sky off to the one underneath........ its just quicker than importing two seperate exposures. ;)
    OR...... try an ND grad filter :)
  6. Philip Weir
    Philip Weir TPF Noob!
    Apr 29, 2006
    506
    Sydney, Australia. The land of peace and sunshine.
    Basically a ND [Neutral density] filter has the same affect, density wise, as stopping down the lens. It is simply a grey [gray] filter. If you shot the subject you spoke about without a ND filter, you would have exactly the same problem. A split screen ND may be the way to go, so you are averaging out your densities, high and low. They are used for instance shooting a moving water scene, where you want to use a certain aperture, but the shutter speed would then be too fast to capture the movement of the water, hence the use of the filter enables you to use a slower shutter speed. "DepthAfield" is on the right track.
    www.philipweirphotography.com
  7. MommyOf4Boys
    Dec 20, 2005
    2,386
    51
    thanks guys. I think I actually have it figured out now too!! Stacking more than one ND filter helped a TON and by metering in manual mode instead of Aperture priority helped majorly as well!
  8. ksmattfish
    Aug 25, 2003
    7,019
    35
    Lawrence, KS
    But neither of these addresses your initial problem which is too much contrast in the lighting, and not enough dynamic range ability in the camera. Correct exposure for the ground, and correct exposure for the sky are just too far apart for current digital cameras (and most film too). You either have to lower the exposure of the sky, or increase the exposure of the ground. Stacking ND filters reduces the light reaching the sensor everywhere in the image.
    To get the correct exposure in a single shot you'll need a split ND to reduce the brightness of the sky, or use a flash to lighten the foreground.
9 stop nd conversion chart
conversion table for nd filters
nd filter chart
nd filter conversion chart
nd filters chart
neutral density converstion chart
neutral density filter chart
neutral density filter conversion chart
neutral density filter exposure chart printab;e
neutral density stop table chart
