D40
- Joined
- May 25, 2007
- Messages
- 475
- Reaction score
- 0
- Can others edit my Photos
- Photos OK to edit
I hope to make this a topic that the D40 users can come to which will help them on lens selection as well as get my lens purchase worked out.
Well, I had a fun day yesterday Woke up bright and early to go get all 4 wisdom teeth pulled out! So, I am unable to do much but sit and either watch TV, sleep OR research my next lens purchase
I now have my D40, 18-55mm lens and the SB-600. I will hopefully be purchasing CS3 as my editing program with in the next few weeks and after that my next large purchase (besides a case and batterie and what not) will be a new lens.
So since I have not barrly moved for the last 26 hours I decided to do some research and then talk to you pros. Here is what I am finding:
I am not going to be able to buy any Pro lenses, anything over $1000 basically since I do not need anything that nice at this point. I have 2 gripes about the kit lens 1. It is cheaply made and 2. The zoom range is not that great. I really would like more zoom but I also have a gripe about cheaply made lenses like the Nikno 55-200 and 18-135 with the plastic mount ring. That just bothers me and I feel that a good lens is going to have a metal mount ring.
So I have considered these lens as the are the most common for the D40:
1. The Nikon 55-200mm lens: Price around $250 complements the 18-55 that I have and give me a great zoom range. The biggest down side is the build quallity.
2. The Nikon 18-135mm lens: This lens is around $350 and I think would be perfect due to price and abillity but the build quallity is a problem with this lens to me. I read that it is between the 18-55 and 18-70mm lens as far as build quallity, and the plastic mount just bothers me. Pictures are very sharp from what I read which is a plus. If not haveing a metal mount isn't an issue than this is a very good choice.
3. the Nikon 18-70mm lens: Price $350ish. This lens has the build quallity that I am pleased with for what I can afford. This lens has the metal mount ring, is overall heavier (should mean better made) and has a rubber ring to keep it somewhat weather resistant. Now it is an improvement over the 18-55 in quallity and adds a slight zoom increase and this lens is very tempting to me at this point. Also at 70mm this lens is a stop or so lower than the 55-200 and 18-135 at 70mm so will perform a little better in low light.
4. The Nikon 24-120mm lens: Price $550-$600ish. A little more pricey but still contains that better build quallity and more zoom. It has the better focus ring unlike the 18-55 and 55-200 which have the focus ring in the front and I do not really like. Now the problem I see with it is you know have a lens starting at 24mm vs 18mm and I think that could be a problem unless you carry your 18-55 around as well. Also for that price you might as well save for the good old 18-200mm lens and get a much more versitile lens. I've heard that this lens may perform better than the 18-200 due to it not covering such a great range but that is all matter of who is reviewing the lens. It does make sence though that that would be true.
5. The Nikon 18-200mm lens: Price $750. Well what can I say, it is a nice lens. It covers the whole spectrum that most people will need and is built well. Yes it does have lens creep but that is only a problem when using a tripod and pointing it up or down while not holding the zoom ring. My biggest problem with it is the price. It also keeps your from changeing lens all the time which prevents dust from enter the camera.
So here is what I am thinking, well let me tell you what I shoot first. At my stage I am doing portraits, shooting events that go on locally and I MAY be shooting as an assistant in weddings so I will not need pro equiptment at this point.
OK, I can get the 18-135 because it has great potention for it's price even though it is not build to my likeing exactly or what may seem more resonable is I can get the 18-70 for the better over all quallity to replace the 18-55 and later I can get the 70-300. I can use the 18-70 for portrait work and weddings and the 70-300 for the oudoor events I will shoot. This would cover a very large range and anly be 2 lens unless I pick up a 50mm price or 85mm prime. Now if I get the 18-135 I will be set longer than if I get the 18-70. I will be wanting more zoom sooner if I pick up the 18-70 vs 18-135. The problem is if I pick up the 18-135 and then desire more zoom I am up the creek because I can either get the 18-200 or the 70-300 both of which over lap the 18-135 whereas the 18-70 and the 70-300 compliment each other?
I hope you don't mind this being long and I hope it will help others like me who are in the same perdicament. My first word of advise is to skip the D40 line from the start and at least get the D80 just to keep form the AF-S thing, unless you are a mother and just want a DSLR for family and kids use. I think the camera is great for such a use and do really like mine, i'ts just I would like to take photography further. If you think you may do more than that than save yourself the trouble and get a camera with an AF motor built in.
Hope this helps.
~John
Hope this helps.
~John
