Nikon D50
Discussion in 'Digital Discussion & Q&A' started by ems3369, Apr 6, 2009.
  1. ems3369
    ems3369 TPF Noob!
    Apr 6, 2009
    11
    West Plains, Mo
    I have a nikon d50 and I am a little new to photography. My question is. When using any of my lenses, Nikkor 18-55, Nikkor 28-80, or Tamron 28-105 I set my f stop to the highest setting on the lens then adjust through camera. When I am at the lowest zoom setting the my f stop will be at the lowest if that is what I set it at, but when I move to the highest zoom then the camera will not let me use the lowest f stop setting. I am looking for a very blurred back ground on my portraits. ex. My 28-105 lens has f stop from 4 to 22. When zoom is set to 28 the f stop can be set to 4. But when zoomed to 105 the f stop will only go to 5.8. Can someone explain this and can it be changed in camera? If so how because I can't find it. Or at least explain why the camera and lenses do this. Thank you.
  2. MrJ
    MrJ TPF Noob!
    Mar 28, 2009
    17
    Sydney
    Hi,
    I'm a newbie with a D50 too (just got it yesterday!).
    From my understanding the maximum apperture setting changes with the amount of zoom. So for the 18-55mm, for example, can get down to f/3.5 at 18mm but only f/5.6 at 55mm.
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
  4. ems3369
    ems3369 TPF Noob!
    Apr 6, 2009
    11
    West Plains, Mo
    Thank you for that information. Guess if I want a good fixed focus lens with multi aperture settings for portraits I will have to go with the 50mm f1.8 lens I keep reading about. I am going to do some test shots with the other two lenses tonight on a model and see how those turn out. Thanks again to all that post.
  5. CrazyCanuck
    CrazyCanuck TPF Noob!
    Jan 13, 2009
    41
    Ontario, Canada
    Fixed focus, is not what your after, your after a fixed focal length lens also called prime lenses. The 50mm f/1.8 is a really good cheap portrait lens, but for a bit more, if your going to be doing a lot of portrait work, I would personally suggest the f/1.4 version. It can blur the background even more(shallower depth of field), and its incredible in low light.
    Not sure about the 35mm f/1.8 DX that came out, but its also a prime. It might be to short for portraits though, and not give a big enough working distance.
d50 photography settings for new borns
f stop nikon d50
f-stop for nikon d50
fstop nikon d50 setting for football games
lowest f stop nikon d 50
lowest fstop on d50
nikon d50 f stop
nikon d50 nikon 28 105
nikon lens for d50 low f stop
what are the number of f-stops in a nikon d50
