jaomul said:If you print larger than a3 regular 24mp may benefit you but otherwise 16mp is loads. The d5100 has a great rep for low noise hi ISO performance and good DR as well. This would allow you editing headroom if you take shots in raw which is good to tweak photos after the event if required. It is usually better to go for the higher spec model, d3200 is nikons entry, the d5100 is up a level but I believe is soon to be replaced by the d5100 so maybe can be got for a bargain now
