One more question...
Discussion in 'Photography Beginners' Forum' started by Reyna, Aug 17, 2009.
  1. Reyna
    Reyna TPF Noob!
    Jun 18, 2009
    321
    8
    Texas
    Sorry for all the silly questions!
    I took a ton of pictures this weekend out in the bright Texas sun. Well, most of them have pretty bad shadows across my childrens faces. I 'think' if I get a speedlight, it will help with this? I took some fantastic photos, but they are ruined with the darn shadows.
    If a speedlight would dramatically help with this, I am willing to spend the money. Any advice or thoughts? Thank you all! My husband says I have become addicted to taking perfect photos.
  2. Overread
    May 1, 2008
    24,068
    4,171
    UK - England
    Welcome to the addiction :)
    A speedlite can help, but there are other things you can use as well
    Firstly the cheapest solution is to shoot later or earlier in the day, when the sun is less intense and the light more diffused. That will give you far less of a shadow problem - of course it does bring its own challenges, because lesser softer light means a slower shutter speed - unless you up your ISO
    Then lets consider that you can't shoot at a different part of the day - well the sun is your main light source and problem - so you can use a 5 in 1 reflector on the diffusion sheet to diffuse the light from the sun - an assitant or a tripod with a gripper/arm attachment can be used to hold the diffusion panel to block the sunlight - this giving you softer shadows. Of course this method is not going to work on kids playing nor most other moving subjects
    Then we get to the flash - and yes it can help also, by using the flash for fill lighting it can effectivly flatten the light over the subject - as in it will fill light into those shadowed spots to lessen their harshness. (and beyond that basic bit of theory I am still working out how to perfect this method)
  3. choudhrysaab
    choudhrysaab TPF Noob!
    Jul 11, 2009
    667
    Toronto, Ontario. Canada
    can you post a sample image to show what exactly you're talking about?
  4. Plato
    Plato TPF Noob!
    Jul 11, 2009
    1,058
    United States of America
    Yes, it will definitely help by filling in the shadows. However, it will not help as much as you might expect. The problem is that the lens must close down substantially because of the sun and it will very probably be closed more than what the flash unit wants.
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    A flash (speedlite) can be used for fill light, which is what you are wanting (to fill in the shadows). You can also use a simple reflector to bounce the sunlight back into their faces...but you would need someone to hold it while you shoot...or a stand of some kind, to hold it for you.
    Another way to avoid the harsh light & deep shadows is to not shoot under that lighting. Find some shaded spots where the direct sunlight isn't falling on your subjects.
  6. Reyna
    Reyna TPF Noob!
    Jun 18, 2009
    321
    8
    Texas
    Ok, thank you all for your help. Most of the pics I take are of my kids and there is no way I could hold up a reflector... they move WAY to much.
    Here is an example... cute picture but that massive shadow ruins it.
    [​IMG]
  7. Reyna
    Reyna TPF Noob!
    Jun 18, 2009
    321
    8
    Texas
    Another
    [​IMG]
  8. Stormin
    Stormin TPF Noob!
    Aug 14, 2009
    139
    Fed Way, WA
    At the same time, you can ask him to move and get him into that shadow to make the shot better, right? :) I know that working with kids can't be easy (there's reasons I have none), but if you want to improve those shots moving the subject may be the only practical way.
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Yes, shooting kids can be tough. Getting a flash can certainly help for shots like this.
