Polarizer filter, or step down ring?
photong
Typo Queen
I have a 62mm lens, and a 58mm polarizer. Is it wise (without risking vigenetting or anything else) to use a step down ring or should I get a new polarizer?
I will be using this on my 70-300, which also has macro.
it also depends also on your foremost glass element in your lens, if that is considerably smaller in diameter than 62mm then it might work for a telephoto lens. best thing is to go to a shop and try. .. or maybe someone from this forum has the exact configutation?
everything else will be pure speculation.
If you can try it out before you buy...then do that. It may or may not cause vignetting...and that may or may not be a problem for you. Ideally, you don't want to use smaller filters on bigger lenses...but it's obviously cheaper than getting a new filter.
Maybe you can sell or trade your 58mm filter to get a 62mm and a step up ring for the smaller lens.
