Her skin actually looks more natural and stands out more! May I ask how you did that? Thanks!
I started with the CR2 file in Adobe ACR. I had no white balance reference but I assumed the university lettering was white paint and her dress was white so I started with those. Fortunately there are two pretty good color constants in the photo -- blue sky (I know what color that is), and human skin (that has an average color that is well known). So after setting the white balance from her dress and the lettering I double check those two constants and arrived at an overall color that I prioritized for her skin. Blue sky at that point was close and I simply adjusted the blue directly.
Because it's a photo I in fact selected a skin color just a smidge warm as opposed to mostly like accurate -- we tend to prefer seeing ourselves a little less yellow than we really are. As for standing out I lightened her in the scene using an adjustment brush.
Joe
Thanks so much for the detail information. I shall practice on that then! I had the idea of brighten her up and stuff, but just didn't know how. I shall look up some practice tutorials.
I actually took a brush (tool) with a very soft edge and set to very low effect and painted over her to lighten just her and not the background. There are lots of options. In LR it's called the adjustment brush. I Photoshop there are other options and specifically I used a brush in Photoshop set to a Screen blend mode which lightens what you brush over.
Glad to help.
Joe
P.S. Look hard and you'll see more that I did -- compare directly above her head for example between your version and mine.
Yes. I can see the blue sky actually feels more blue. You also made the sky across the picture / angle and fixed that weird distorture thing I missed.
You had a great idea to pose her in front of the univ. sign like that -- good job. But you got very close with a pretty wide lens and you held the camera down below her eye level -- basically looking up at her a little. Add those together and there's the distortion you noticed. I used a software program from DX0 called Viewpoint that helps correct distortion problems like that.
Joe
Haha, I see. There was actually a reason for me getting up close because I wanted to use my camera's flash to fill in the shadow since lighting was pretty bad at the time with the sun above our heads creating shadow. Since I don't have any powerful lighting flash (I should invest in one soon), I just had to make do with what I had by getting closer to her so the flash can reach and fill the shadow, but I totally forgot about that distortion thing with the wide angle lens.
Tamron 17-50mm f/2.8 if you're wondering.
But thanks! I just need more practice.
