f/22 is probably overkill. You should stop down a bit, but mainly your DOF is very shallow because you are quite close to the subject. As you move back further, you DOF will increase. Try f/8 and standing 6-8 feet away.
Also notice how shallow your DOF is on the hat, The front of the bill, and the top right where it meets the front are both blurry. You DOF is about 2 inches in this photo. This can be very useful in some cases for isolating a subject, its just a matter of learning to make it happen when you want it. Same goes for the flowers. The flowers are a bit overexposed, you should dial down you Flash. I think it is under FEC, or Flash exposure compensation in your manual.
A good exercise would be to arrange a bunch of objects on a table each one several inches back from the next, and staggered so you can see them all at one, use maybe 4 action figures or blocks(it helps if you have kids toys!) then use a tripod, or at least stand or sit in the same spot about 5 feet away, start by focusing on the front object, and take shots at say f/2, 2.8, 4, 5.6, and 8, then move back to about 10, or 15 feet away, and repeat the process. Then compare all of the shots on you computer. This will give you a good feel for DOF in relation to the distance between you and the subject.
Also do a google search for "understanding Depth of field" or "Apurture and depth of field"
