Sideburns
- Joined
- Aug 14, 2007
- Messages
- 2,796
- Reaction score
- 0
- Location
- Windsor, Ontario
- Can others edit my Photos
- Photos OK to edit
Well that's the problem with what you're doing. RAW files are all proprietary, the files all change format, the software all changes, and you might find that a year from now none of the RAW software out there will work with your D1 files anymore at worst, or just doesn't seem to handle them well. This is especially true since the D1 is a pretty old camera that not a whole lot of people shoot with anymore. There's little reason for software developers to keep supporting old D1 files considering that so few are still used. You might have to dig up some extremely old software to use the files, which then might not even run if it wasn't designed for the newer operating systems out there which all change too. This is why RAW is a horrible format for archival or if you're not going to immediately process them into JPGs. That's why I'd strongly recommend shooting JPG for now, which is universal. You can still do a ton of processing on JPGs too, if that's what you're interested in.
In the rare cases I shoot RAW, I shoot RAW+JPG, and then when I'm working through my photos doing post-processing I still usually stick with the JPGs. Once in awhile I'll find a good keeper photo that I've managed to screw up badly enough to process from the RAW file instead. Once I have all of my post processing done and have my final images, I DELETE all of the RAW files since they just eat up a ton of disk space.
You read too much Ken Rockwell. That guy loves to blab bad about anything he doesn't do and say it's stupid.
.DNG was created just for this reason...so even if you don't trust RAW format...just convert to .DNG (digital negative)...
I say if you are used to shooting with film...and are fine with the results...then just shoot with jpeg for now.
