Resizing Photos
Discussion in 'Photography Beginners' Forum' started by B192734, Mar 7, 2008.
  1. B192734
    B192734 TPF Noob!
    Mar 5, 2008
    47
    Portland, Oregon
    Does anyone have advice on good software of techniques for resizing photos to post here? I have tried, and no matter what I do I continually get pics that are to big. They don't fit inside of the screen. Here's an example:
    [​IMG]
    Anyone have any advice? I've tried but am kind of lost at the moment...Thanks for any advice.
  2. B192734
    B192734 TPF Noob!
    Mar 5, 2008
    47
    Portland, Oregon
    Nevermind. I figured it out. Finally. Now I just have to figure out how to post from Picasa. Photobucket works, but I normally use Picasa. Anyone have any insight on that?
  3. mrodgers
    mrodgers No longer a newbie, moving up!
    Dec 13, 2007
    1,662
    7
    "Too big" is directly related to the individual's screen resolution when viewing. That said, 1024x768 screen resolution is still common and it really bothers me when images do not fit on 1024x768. In forum use, I would post photos no more than 900 pixel on the horizontal side to fit on the screen of 1024x768 resolution (I think 900 is the size that fits).
  4. Big Mike
    Dec 16, 2003
    33,854
    1,818
    Edmonton
    There are two things you need to do before uploading for web viewing.
    Resize: (change the size of the image (in pixels) to about 800 (longest side))
    Compress: After resizing, you need to save the image before uploading. Save as a JPEG and then set a compression/quality level that will reduce the file size.
  5. B192734
    B192734 TPF Noob!
    Mar 5, 2008
    47
    Portland, Oregon
    So in your opinions...Is the picture posted in the first one to big, or would people find that acceptable?
  6. Sandspur
    Sandspur TPF Noob!
    Jan 30, 2008
    241
    Pensacola, FL
    It's too large.
    A general rule of thumb for posting: (whatever image management software you're using) choose "Save for Web" which is an automated way to convert a file from it's original resolution to 72 dpi. Then, if you have the option to adjust image size, choose 600 for the longest dimension) and apply that change. Then you can check to see how large the new file is. For optimal viewing quality AND optimal uploading time it should be no more than 100K for most sites, which you can adjust by changing the "quality" setting.
    At least this is how I do it in Photoshop. I think most other PP programs have something similar.
  7. B192734
    B192734 TPF Noob!
    Mar 5, 2008
    47
    Portland, Oregon
    Thanks a lot. I am looking at some options for phtot editing software right now, so I'll make sure that's something that is an option. Thanks again.
