- Joined
- May 1, 2008
- Messages
- 25,422
- Reaction score
- 5,003
- Location
- UK - England
- Website
- www.deviantart.com
- Can others edit my Photos
- Photos OK to edit
BlackRapid: SPORT
So I got one of these today and whilst I've not given it its full paces I've got some early thoughts.
I should say when I first saw these I never wanted one. I didn't see the point over a good neckstrap with proper padding (eg OPTech neckstrap) and that any lens too heavy for the neck would be too heavy for one shoulder.
However I happened to encounter another photographer using one and was struck by its ease of use; its effortless ability to take the lens away from the face and support it whilst holding it at a more natural resting position to make walking easier (with or without a hand atop the camera to support it).
Indeed any lens that is somewhat large on a large camera can be quite a pain around the neck.
Thus I got one (well got given one upon occasion of reaching another year on this earth).
Early thoughts:
1) It's very easy to use and takes weight effortlessly off the neck and arm and puts it on the shoulder; far easier to carry there. The padding is touch and firm and well suited to holding shape whilst under tug.
2) It is a shame that the under-arm stretch is flat rather than rounded fabric; not a problem with a shirt but with a light shirt in summer it might cause some rub that a round strip of leather might not cause. Granted this part doesn't pull tight and is there for support; but still rounded would have been preferable.
3) The screw mount is secure and easy to use; although if you use arcaswiss style plates it can be a bit of a pain as some don't have screwthread slots (mine for my 70-200mm has not got one- or rather it has one at the front in a recess and thus of no use for this).
That said its a matter easily resolved with one of these
Andoer® Aluminum Quick Release Plate Clamp Compatible: Amazon.co.uk: Camera & Photo
(there's a range of similar ones under various names). A simple plate to attach to the screwthread mount and to then lock into the arcaswiss mount on the camera+lens
4) I have a minor reservation about its practicality on a lens collar; although I've not yet put this to the test (hope to in the next few days when the afore mentioned plate arrives).
Overall, despite my ramblings up there, I'm very impressed in this; its simple and yet works really well. I'd recommend them heartily!
UPDATE AFTER A FULL DAYS USE
Update after a first days use: On 7D with 70-200m f2.8 IS L MII
1) Using the quick release plate (as linked earlier) I found that it held the camera well and without any worry attached to the base of the camera. I did, however, find that attached to the tripod collar was a bit of a problem - the natural position for hte collar on my lens is raised over the top (so that the collar is out of the way of the hands) but that's not a good spot to pivot nor hold the camera on the strap. This might be different with a much heavier lens; regardless the 70-200mm f2.8 isn't a problem hanging from the camera mount (its something i've normally done for years already without the strap); thus the black rapid went on the camera.*
2) I found that with the quick release plate and the black rapid it was effortless to let the camera hang by my side and let my right arm only steady it; intead of having to hold it. By the end of the day this really showed as a bonus; noramlly after days shooting my right hand would get an ache in the fingers - even using a wrist strap it still put pressure on the fingers to support the camera and lens weight.
Thus the black rapid really took the pressure off my arm.
3) I prefer letting the camera hang on the shoulderstrap instead of on a neck strap - the shoulder strap moves it out of the way of ones arms and whilst taking the weight on the shoulder not the neck. It's less annoying and whilst the right arm still has to steady teh camera when moving its no different to having to steady it against ones chest when moving (only that now you don't have to have your arm bent up to hold it and can have it in a more relaxed position).
4) The setup I had made the bulk on the base of the camera (where I've got a battery grip) a bit of a pain to shoot in the portrait aspect. In addition I'm not the tallest of people and as a result the strap can feel a little "short" when put into the portrait.
HOWEVER even though the distance is slight if I moved the quick release bracket from the middle of the camera to the edge (taking advantage of the sliding along the length of the arcaswiss plate on the camera) I got the bulk moved out of the way of my hand and got a little more distance with the strap - resolving the problem without any fuss.
Overall it works really well and I think it will fast be something that I will hardly not use; indeed using the quick release plate with the arca swiss setup its even easier to "not" use it - one just doesn't take the strap and there is nothing to add nor remove from the camera. This beats even OPTech neck straps and their removable main strap body.
I would say that I didn't try this yet with my 120-300mm f2.8; but I supsect it wouldn't work quite as well; indeed I think it works best on a lens that can comfortably hang from the camera mount whilst the strap is attached to the tripod screw on the base of the camera body (or onto a plate there). Which in practical terms means a 70-200mm f2.8 is likely the heaviest lens one will likely use it with.
* Note many use this lens for hours without the tripod collar; indeed were it not for the neoprine cover on my lens I likely would have the collar off any day using it without the tripod; thus to have the black rapid mounted to camera not tripod collar, on this lens, I suspect is very normal
Early thoughts:
As an Amazon Associate we earn from qualifying purchases.
