SB-800 owners
Discussion in 'Photography Equipment & Products' started by plastii, Nov 1, 2007.
  1. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    Hi.
    Guys, what kind of batteries do you use with your sb-800? Should I go with more expensive one? (NiHM)
    Thanks
    Marek.
  2. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Definitely go with Rechargeables...NiMH are good. It will cost a bit of money upfront to buy two or three sets of them...but they work much better than alkaline batteries and alkaline batteries aren't good for the environment anyway.
    Check out this site for batteries and chargers etc. http://www.thomas-distributing.com/index.htm
  3. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    Cool - thanks:)
  4. Patrice
    Patrice No longer a newbie, moving up!
    Dec 6, 2006
    2,392
    381
    Campbellton, New Brunswick, Canada
    I agree with Big Mike, rechargeables are less expensive than alkalines in the long run. In some situations I need really fast recycles and then I power the SB800's with external lead acid gel cells.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Check in the manual. Every type of AA battery is listed in there along with the shot life and cycle times for both 4 and 5 battery configurations.
    Mind you a set of NiMH with long shelf life would be good. I do believe a few exist.
  6. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Don't bother spending 9.95 for a pack of 4 rechargeables, they won't last you half as much as the batteries that are a little more expensive.
    I bought some decent performance NiMH batteries that came with their own charger. The kit cost $39US and I bought an extra set of batteries that matched the ones that came in the set for another $23US. I get about 190 flashes on my SB-800 with these vs about 75 from the cheap rechargeable ones.
    Here, like in most things, you get what you pay for.
  7. ilockert
    ilockert TPF Noob!
    Sep 4, 2007
    207
    Gulfport,Mississippi
  8. kundalini
    Jul 18, 2007
    13,608
    1,933
    State of Confusion
    I recently upgraded my Ni-MH rechargables to 2900mAh here. B&H now says it's discontinued, guess I got lucky. The point is, if you buy NiMH and you should, get the highest mAh rating you can find. That 10 pack cost me $25USD and I got a slow charger for about $11USD. Don't get a quick charger, it will eat into the battery's life.
  9. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    Thanks for the info guys. Now I can go shopping:)
  10. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I recently purchased one of these chargers for my batteries. It allows for several different changing rates...so I can charge them slowly to give them a long life...or I can charge them fast when I need. It also allows me to fully discharge them before recharging...which keeps them at a high capacity. I've heard from several people that it's not uncommon for these batteries to have a lower capacity than what they are rated at...even new ones. This charger can test batteries and then refresh them with repeated charge & drain cycles.
  11. plastii
    plastii TPF Noob!
    Oct 12, 2007
    317
    Gilberts, IL
    That's pretty cool, but I also like this one:
    http://www.thomas-distributing.com/maha-mh-c800s-battery-charger.htm
  12. XJBaylor
    XJBaylor TPF Noob!
    Dec 5, 2004
    63
    I highly recommend the Eneloop (or similar) batteries. They hold a charge for a long time, and seem to behave identically to the 2900 mAh batteries I have.
    Keith
