Settings
Discussion in 'Photography Beginners' Forum' started by Bodine43, Feb 3, 2010.
  1. Bodine43
    Bodine43 TPF Noob!
    Jan 31, 2010
    Florida
    I have a canon t1i and was wondering if someone could tell me some good settings for 75-300mm lens for baseball any help would be a plus thanks for your time in this matter.
  2. JSD
    JSD TPF Noob!
    Aug 9, 2009
    138
    Colorado
    That's a broad question and hard to answer becasue of so many variables. You might start with the "action" setting if your camera has one. You could also use shutter priority which would allow you to choose a fast shutter speed and the camera would set the aperture. You might need to boost the ISO if the light is not the best and set white balance to auto to start, or if you know the color temp of the light source set it accordingly. Hope this helps...JSD
  3. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Av, wide open, ISO high enough to stop most action, low enough to have acceptable noise levels.
  4. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    5,577
    716
    Woodbridge, Ontario, Canada
    Keep shutter speed equal or higher than focal length of lens.
    ie. if your lens is at 200mm ... keep shutter speed at 1/200s or faster.
    Adjust ISO if necessary.
  5. KmH
    Apr 9, 2009
    38,754
    5,162
    Iowa
