Something wrong with my enlarger
Discussion in 'The Darkroom' started by KevinR, Apr 24, 2005.
  1. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    I am getting two white streaks on my prints. They are not very defined but very visable. I am sure it is some thing with the path of light but I can't find it. I did some different sizes to see if maybe it was the paper. It reduced proportionally with the print. I took apart the enlarger and blew it out but it was still there. I can't see anything when enlarging it on my board. This is starting to drive me nuts.
  2. oriecat
    oriecat work in progress
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Where is it showing up? Do you have a scan you can show us?
  3. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    I don't have a scanner hooked up right now. It is two white streaks going about half way across the print. Almost looking like a lens flare. I guess I am just going to disassemble the whole enlarger, clean everything good, then put it back together, hopefully without extra pieces laying around.
  4. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    Still getting the lines. The alignment as far as I can tell is good. Its not that complicated of an enlarger (Omega C700). Has anybody had or heard of a bulb throwing strange shadows through the light path. I'm running out of ideas. I will try to get a print scanned to post. This is becoming way too complicated. :x
  5. oriecat
    Jul 7, 2003
    3,117
    19
    Portland OR USA
    Hmm. I had trouble once with an easel I was using reflecting a line into the print. Could it be something like that?
  6. omalley
    omalley TPF Noob!
    Mar 31, 2005
    55
    NYC
    Is the Omega C700 a dichroic enlarger? You probably already checked this, but could it be a problem with the diffusion glass piece thing under the bulb? Is it damaged? Maybe you could hold it up to the light, look through it, and see if there is a problem.
  7. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    The easel was one of my first thoughts, but when I reduced an image down to 4x6 and the marks reduced along with it I was able to rule out a reflection around the enlarger. These are white marks so I am assuming it is obstruction of the light path. The diffusing glass looks good. My only real reference though is this glass. I can't see anything on it. What is driving me crazy is that I would have figured that without a neg in the holder, I would be able to see a little bit of the shadowing and I can't. Thats with moving the head all the way up or down.
  8. KevinR
    KevinR TPF Noob!
    Feb 1, 2005
    1,204
    4
    Dearborn, MI
    Someone mentioned maybe I got a crappy bulb. The lines might be from the filaments. I'm going to run a few tests tonight when I get home.
