spot metering on 350d
Discussion in 'Digital Discussion & Q&A' started by mentos_007, Apr 22, 2006.
  1. mentos_007
    mentos_007 The Freshmaker!
    Jun 29, 2004
    9,324
    102
    Poland, Sz-n
    I read somewhere that 350d doesn't have spot metering. and then i read at dpreview that it has something like 9% center point metering... is this... the same what spot metering is?
  2. Trevor
    Trevor TPF Noob!
    Apr 11, 2006
    69
    Bradford, ONT
    Umm, I have the 350D and could probably help you out, but I never had to figure out what spot metering is.
    When I look in the menu I can find metering. There are three icons, empty half and full. I can also point it at lights (did this today) and it will give me a numerical reading on the light amount... I dont know how I did this though. (Back to the manual hehe)
  3. Azuth
    Azuth TPF Noob!
    Dec 25, 2005
    262
    Sydney 'strailya
    The 350d doesn't have spot metering. Spot metering is tighter still, (about 3.5% in the case of the 30D). 9% is still good, just make sure the area you're metering is covered by that 9% and you'll be fine. You may have to get close or zoom in to meter, then move of zoom out to use the information you gained
  4. Meysha
    Meysha still being picky Vicky
    Feb 21, 2005
    4,152
    58
    The spot metering isn't always the tightest as Azuth mentioned. But like anything, you'll get used to it. And you'll start to look at the readings you get and go ... hang on... that can't be right. And that's when you zoom in and meter.
    You shouldn't have any problems mentos!
  5. thebeginning
    thebeginning TPF Noob!
    Jan 10, 2005
    3,795
    30
    Texas
    azuth is right, it does not have spot metering. perhaps you read somewhere about the center weighted metering system, which might have a 9% 'spot' in the middle, but it does not meter entirely from that.
  6. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    If it has the same three metering modes as the 20D...then it will have Full Matrix, Centre weighted Matrix and centre only.
  7. bauerman
    bauerman TPF Noob!
    Apr 24, 2006
    31
    Idaho
    On the 350D what you are referring to is called "partial metering" rather than "spot metering". Spot metering is something that was recently added to the Canon 30D.....and it is a much smaller percentage of the shot that is used for the exposure calculations.
    You have three options - partial, evaluative and center weighted. I really think that Canon SLR's do quite well with simple evaluative metering - although I will use partial every now and then for a backlit subject.
    Jared
