teleconverter for sigma lens?
Discussion in 'Photography Equipment & Products' started by jensgt, Jan 28, 2010.
Thread Status:
Not open for further replies.
  1. jensgt
    jensgt TPF Noob!
    Nov 21, 2009
    242
    16
    Bowie, MD
    I have been thinking about getting a teleconverter to be able to get a little closer to birds and such...but it seems that sigma does not make one that goes with the 70-300 APO DG Macro lens that I have for my Sony Alpha. Looking around it seems like I would need a new lens...none in the affordable range for me right now. Anybody know if another company makes teleconverters that work with Sigma lenses? Or a combo comparable lens/teleconverter combo that would not combine to be like way over a thousand bucks? Its not something I have to have right now...but would like to in the future. Right now I just started going to school...so it could be a while!! lol
  2. PhotoXopher
    PhotoXopher TPF Noob!
    May 27, 2009
    3,475
    Maybe Kenko?
  3. Overread
    May 1, 2008
    24,079
    4,174
    UK - England
    Kenko is your best and only chance I would exepect for a good quality teleconverter that would fit. However there are two possible problems with this. The first is that even the kenko teleconverters might not fit the lens itself (test in shop if you can't find someone to confirm this).
    The other problem is that adding a teleconverter takes away one stop of light from the setup and will also affect the image quality of the final shot. That means you lose one stop making it an f8 lens at the long end which will most likley slow your auto focus speeds and the accuracy of the AF.
    A 2*teleconverter I would not use - 2 stops of light lost would make it far too slow a len and the image quality would take a very significant image quality drop (even top range 70-200mm lenses have trouble with the 2*TC).
    Overall if you want more zoom I think your best bet is a different lens. Perhaps consider the Sigma superzooms - 50-500mm, 150-500mm as cheaper options
  4. LeoLady
    LeoLady TPF Noob!
    May 18, 2010
    New York State
    Do NOT get a Kenko - I just found out they are known to screw up Sigma Lenses - this info came too late for me - I have had 2 Sigma lenses repaired and 2 more in for repair - as a result of using as Kenko teleconverter with them - I THOUGHT it was my camera and bought a new one (no choice, I was in India) and the Kenko teleconverter screwed up the SONY kit lens too. Yep - I had to buy another camera. Very expensive trip.
    NO KENKO!!!
  5. gsgary
    gsgary Been spending a lot of time on here!
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
    That lens is not good enough to handle a tele converter
  6. Overread
    May 1, 2008
    24,079
    4,174
    UK - England
    Leolady - what specific lenses and teleconverters were you using and what problem did you experience with them? Its the first time I read of kenko teleconverters messing up sigma lenses.
  7. myfotoguy
    myfotoguy TPF Noob!
    Feb 15, 2010
    855
    Minneapolis, MN, USA
    My Tamron 1.4x Pro (supposedly the same thing as Kenko, one makes the other, but that's just rumor, have not verified it).
    Anyway, that didn't screw up the Sigma 50-150 2.8 I had, but auto-focus was behaving very erratically. When I got a Sigma TC, all worked great. I have read this from other users too (dpreview forums). Other folks have experienced sigma lenses not playing nice (my experience was focusing) with other TC's.
    This is Nikon mount by the way.
  8. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    It is not just the loss of light that makes a TC inappropriate for some lenses. A TC always will degrade image quality to some degree (some more than others) because you are adding additional glass elements between your lens and your camera. This may not be very noticable if your main lens is very high quality, but it will magnify the flaws of a lower quality optic. TC's tend to work better with primes than zooms, but I use a 1.4X with my zooms (the sigma matched EX series) with decent results. The 2X is terrible with my zooms (I haven't gotten rid of it yet because I am waiting to see how it does when I buy a long prime).
  9. gsgary
    Oct 31, 2008
    16,144
    2,945
    Chesterfield UK
  10. jensgt
    jensgt TPF Noob!
    Nov 21, 2009
    242
    16
    Bowie, MD
    I realized that nothing would work with my 70-300 so I just got the 150-500 instead. Might add a 1.4 to that one day...but for now its awesome.
  11. gopiqpp
    gopiqpp TPF Noob!
    Apr 17, 2012
    Dammam, KSA
    You must be mistaken. In the past two years I've used Kenko 1.4 and 2x TC's extensively with my Sony kit lenses as well as the Sigma 150-500mm lens. No problems like the one you describe. Where did you hear about this problem with Kenko? Can you name the source? I did extensive web scouring to find similar instances of lens damage after using Kenko TC but your post is the only one in the world wide web to mention it. Hard to believe.If Kenko was that bad there should be many forums talking about it.
  12. SCraig
    SCraig Been spending a lot of time on here!
    Nov 12, 2011
    6,407
    2,401
    Nashville, TN
    This topic has not been posted to in over two years. I sincerely doubt that you are going to get an answer.
Thread Status:
can you use a kenko teleconverter with a sigma lens
has anyone used a sigma 2x teleconverter with a sigma 18-250 lens
sigma 17 50 with teleconverter
teleconverter for sigma 17-50mm
teleconverter with sigma 17-50
