The background is not white
Discussion in 'Photography Beginners' Forum' started by akazoly, Jan 13, 2008.
  1. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    This is my light tent (home made) using this tutorial http://digital-photography-school.com/blog/how-to-make-a-inexpensive-light-tent/ :
    [​IMG]
    I take the photo in manual mode, at F4. The background is not perfect white, I use a DAYLIGHT bulb (6400 K). The same problem happen with two bulb.
    This is the result:
    [​IMG]
    I try to shoot in RAW. But I don't know what I need to set to correct the gray background and this settings affect the image ? I think RAW is not the best solution for me. I want to keep the image quality.
    I use spot metering. Now I don't have more idea, anyone has a sugesstion ? How to correct this problem to achieve a white background ?
    Thanks!
    [​IMG]
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    The white balance is correct. All I had to do to get it to pure white is push the exposure by about a half stop in DxO. You could do the same thing on the camera.
  3. Battou
    Battou No longer a newbie, moving up!
    May 10, 2007
    7,997
    26
    Slapamonkey, New York
    You could try putting up white walls on the sides as well, I have not yet used a setup like that but I am fairly sure a little more reflection from the sides would clear that up.
  4. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Can you help me a bit and explain me in more details what is Dx0 ? I need + or - exposure ?
  5. Dominic
    Dominic TPF Noob!
    Dec 4, 2007
    77
    Maryland
    You can try using a gray card for your metering.
    Looking at your set-up, have you thought about using some tracing paper as a diffuser?
  6. Fate
    Fate TPF Noob!
    Jan 8, 2006
    1,685
    67
    England - Worcestershire
    I had silmilar issues with my studio shots at college... mainly cus the backdrop was dirty as lol, but it came out grey. I fixed it by shooting RAW and then making two convertions.. one fairly blown out one for the background and then one correctly exposed one for the subject.
    Worked for me
  7. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I need aluminium foil under white paper?
  8. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    I wait more suggestions, please.. Thanks!
  9. Dominic
    Dominic TPF Noob!
    Dec 4, 2007
    77
    Maryland
    I use a gray card (Available at most any camera store and even in the back of some photography books. Actually, one of the British mags has a gray card included in this month's issue -- the one with the squirrel on the cover) for all of my home studio shots. I didn't want to buy a hand held meter and a gray card will help a great bit.
    As far as the tracing paper goes, if you'd like a cheap fix to harsh lighting, you can create a diffuser by using some tracing paper around the front of the light. I've built my home studio out of such ideas I've read about and numerous trips to the local fabric, hardware, and craft stores. Best of luck.
  10. jamesino
    jamesino TPF Noob!
    Dec 9, 2007
    115
    Not sure if this has been mentioned already. The tutorial says to cover up the sides of the box with white paper too. In your picture, the sides were not covered, which would explain the grayish side-vignetting on your photo.
  11. akazoly
    akazoly TPF Noob!
    Jan 3, 2008
    236
    Is a good idea to light the box from bottom ?
  12. Battou
    May 10, 2007
    7,997
    26
    Yup it's been mentioned.
