The "Gray" Area in Exposure Settings...
Discussion in 'Photographic Discussions' started by slickhare, Mar 12, 2006.
  1. slickhare
    slickhare TPF Noob!
    Nov 26, 2005
    678
    10
    cali
    so when i've been shooting lately, i've found that i like to deal with absolutes. in that, i use a really open ap or really closed. and if the metering tells way different i'll correct. but i began to wonder...
    having the luxury of a digital camera, i can shoot stepping up or down in as small increments as i wish and see the results immediately. however i wondered how people using film cameras can find the sweet spot in the "Gray" area of the settings?. for example, my shutter speed can go from 1/4000 of a second to bulb. i mean sometimes a faux pa and i correct it. but i was wondering how people using film cameras (and digital too for that matter), can find the exact settings they need on a dime?
  2. Dawn Roberts
    Dawn Roberts TPF Noob!
    Jan 31, 2006
    40
    CA
    Well, when I shot film, I had to fully trust my meter..either in camera, or external. After shooting film for a long time, and knowing how certain films are, you can easily figure out where you should be based on your camera, lens, film, and lighting conditions. With film, I personally paid much more attention to all of that than I do with digital. With digital, I know I'm able to instantly see my results, so I don't pay quite as much attention. Obviously, if I'm in a situation where I don't have the opportunity to take a shot and check my histogram, I do pay attention. Digital has made me lazy....however I still know the basics, which is important.
  3. DestinDave
    DestinDave Master of Non Sequitur
    Jan 29, 2006
    480
    Not where I thought I'd end up
    When possible (and when I remember) I use an 18% Gray Card... And I bracket a lot of shots... +/- 1 stop...
  4. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    Well you typically have an automatic sweet spot at sunny 16. But yeah, i either shoot at 5.6- or at 22+. Occasionally i'll shoot at 16 or 8, but rarely anything else.
  5. Hertz van Rental
    Hertz van Rental TPF Noob!
    Nov 8, 2004
    16,728
    45
    Where am I now?
    A good 35mm or 6x6 will give you at least 1/2stops on the aperture. 5x4 and 10x8 will give you at least 1/3 stops.
    You take a highlight reading and a shadow reading to get the dynamic range of what you are doing and adjust lights/reflectors to get the balance how you want it then peg the exposure where you want it (even when shooting outdoors).
    Shoot some Polaroid to check.
    Shoot your film.
    Get a clip test done by the lab and assess. Then tell the lab how you want the film processing.
    Simple.
    Or at least, that's how it was done when I was working as a pro.
    (And it explains why we got paid so much :lol: )
  6. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    Using B&W film as an unpaid amateur [with a deep respect for the pro's]:
    1. Standardize exposure meter/camera/film/development.
    2. Determine exposure for shot [gray card, shadow/highlight, etc. as modified by experience.]
    3. Make decision on aperture/shutter speed [DOF vs. 'freezing' motion.]
    4. Set camera and shoot. Bracket if uncertain about exposure or to explore DOF/motion effects.
    I don't recognize a 'sweet spot' as such. There's a range of options for each shot. Choice depends on the expected final print.
  7. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Histogram works well for me. Generally if I open 1/3 of a stop I will have a good file to work with. Film is sort of the same. I would shoot 400 asa at 320 because I knew my camera (for a lot of different reasons) needed that extra 1/3 of a stop to produce a "good" exposure. Test a variety of lighting and exposure settings to figure what works best for your camera and most used lens. If you have access to a densitometer that is the way to go. The idea is to rely on the meter reading so that there is not too much playing around with the exposure. This will give you freedom to experiment with ƒ stop and shutter combos. Personally I try not to bracket.
    Meter readings and grey cards are important. Mandatory in my commercial biz. Experience will help you to figure out the "sweet spot" with out those tools. Allowing you to find the exact settings on a dime.
    On one hand I miss clip tests and Polaroids. On the other; I am thinking of getting a laptop for the commercial end. That is the wave of the future.
  8. ThomThomsk
    ThomThomsk TPF Noob!
    Oct 27, 2005
    441
    50º north
    The breakthrough for me was realising how my camera's meter works (i.e. it sees the world as 18% grey). Then reading about the zone system and working out what that meant for me as a roll film user. Expose for the shadows (I can do that) and develop for the highlights (that's the next step, which means film tests to pin down my personal film speed and development preferences). And I need (well, want really) a spotmeter, to make it easier to measure the dynamic range in a scene and decide where I want to place my deepest shadows.
    Fun, ain't it?
    Thomsk
  9. Terence
    Terence TPF Noob!
    Mar 31, 2006
    4
    When using film be it colour or B&W, there are three easy ways to get an 18% grey reading - (1) meter off your hand (2) meter off Grass (not the smoking kind) (3) meter off concrete, like the sidewalk. Alternatively bracket the shot i.e. shoot 1 stop either side of the meter reading (for film) or 1/3 stop for transparencies (slide) - one of the shots will be 'perfect'. I'm probably the 'oddball' in this group because I refuse to use Digital. Perhaps as a 'purist' and as a professional photographer for the last 30 years, to me Digital Imaging is exactly what it says - it is not photography. While post production is necessary with Digital, giving all sorts of 'benefits' in manipulation etc., this is also available with film, once it is scaned - the real problem at the end of the day is whether the client who is paying usually a relatively high fee, is receiving a 'true' photogrpah or a Digitalised Print. Photography is a learned and acquired 'art' over many years. Some become famous as a result of their 'skill'. I wonder in years to come who will be famous as a result of computer generated images? Would anyone pay $1million for a Rembrandt painted by numbers?
  10. darin3200
    darin3200 TPF Noob!
    May 3, 2005
    2,078
    28
    Des Moines, Iowa
    Whenever I shoot with my zorki c (no light meter) I just guess. A general rule of thumb being f/3.5 at 1/25th indoors with iso 800 and f/16 1/500th outside if its sunny. Guess inbetween
  11. ksmattfish
    Aug 25, 2003
    7,021
    34
    Lawrence, KS
    It works just like digital. You shoot photos, you see how they turn out, then you go shoot more photos, and see how those turn out, and so on. It just takes hours or days to see how the photos turned out (unless you're using Polaroid). After you do it enough you know what works for you in certain situations.
  12. ThomThomsk
    Oct 27, 2005
    441
    50º north
    Generally I find that the back of my hand needs a stop more than 18% grey, the palm of my hand a stop and a half, although of course this is after a long dark winter and by August these numbers may have changed!
    I wouldn't bank on it Terence. Some of us have even given up digital and gone back to film.
    Thomsk
