Three articles about bokeh: out of focus rendering in photography
roentarre
This is a set of 3 articles stating the nature of bokeh and the use of bokeh in photography terms...
Part I What is bokeh?
What is bokeh?
Part II Types of bokeh
Types of bokeh
Part III Standard of bokeh and how is it derived?
Standard of bokeh
I hope you enjoy the articles in deed
Regards
James
The second and third links go to the same web page.
Nisen Bokeh
Of all the different types of bokeh that photographers use, this one is most hated by people who like to look at photographs (and even those who don't.) They might not know the technical term for this technique, but they don't like it. This style is known because it goes beyond just blurring the image and can have an effect on the photo, causing it to be distorted. This can really detract from the overall picture sometimes, which is why so many people don't like it. Also, it's used a lot by amateur photographers who can't pull off the more advanced bokeh techniques.
It doesn't really have anything at all to do with the skill of the photographer - it is entirely based on lens selection. This type of bokeh is what you get when using mirror reflex lenses.
You seem to imply that getting bokeh in your photos is a 'skill' that can be learned, and that you can even learn to have a specific type of bokeh.
It has more to do with the lens than anything else. Shooting with a large aperture will give you bokeh every time, assuming that there's something in the background to be out of focus.
The quality of the bokeh is a product of the lens design. There is no 'technique' that you can learn. The more aperture blades a lens has, the smoother the bokeh will be (if you had a lens with only 3 aperture blades, the bokeh would be triangular). Also, the blades on some lenses have straight edges, while others are curved - that halps to smooth it out too.
Mirrored reflex lenses will give you that ring shaped bokeh which most people find to be ugly.
EDIT
You can also make the bokeh any shape you want by making an aperture disc that you could tape to the front of your lens.
For example, you could take a piece of black posterboard, cut a heart shape from the center of it, tape that to your lens - now you will have heart shaped bokeh.
You could do the same for any other shape too.
assuming that there's something reflective/reflecting light in the background to be out of focus.
Fixed. Remember folks "bokeh" is out of focus light sources.
Ah, yes - sorry about that. ;)
...Although - *almost* everything reflects at least some light, so I think the term could still be used to describe the general out-of-focus background area.
As with many words this one appears to have gone through a bit of a change in meaning as it enters common parlance - most people consider the bokeh to be the general out of focus areas in the background and most explinations I come across or have been told also fit this description.
And I guess OIIIIIO is right - provided the background is not black some light is being reflected and thus the elements in the background become a lightsource ;)
Also the last page of the article reads a bit like a Lecia ad/promo. If your going that line then you need to prove it to people not just say it - give people good examples of other brand bokeh and then compare to examples from lecia lenses. Otherwise it just comes off as rather elitist.
I also fully agree with OIIIIIO point on the nisen bokeh
Nisen Bokeh
EDIT
Catadioptric mirror lens are not the only source of ring shaped bokeh.
Water droplets will give the same effect as will any small round reflective objects providing specular highlights in the background.
hmm I have had waterdrops and wet things in my macro work get close to the doghnut shape, but its never as pronounced as it is from the mirror lens example shots that I have seen
