what could i do to these?
Rob A
North Wales
Website
photobucket.com
hey guys, i was wandering if you could help. i got my new 300d today and i just this second took these shots. ino there not great but its sooo overcast here so it was dificult to get anything good. i was just wandering if you could think of anything to make them better in photoshop or somthing etc.... thanks for ANY input!!!
I'd try to use photoshop and the channel mixer.
Put it on monochrome and change the levels until you see the sky and stars a bit better. Then some contrast and it's okay. Try to crop about 1 cm from the bottom of the pic and it'll be good.
Did you shoot in raw? If so they are quite fixable. If not, I'd say your going to have a lot of noise. If you use it to your advantage then it could work.
no i shot these ones in large fine (i shot everything else in RAW ><) ill try using the channel mixer. im quite a novice so it wont be too good :/
