What do you think
Discussion in 'General Gallery' started by mwcfarms, Sep 20, 2010.
  1. mwcfarms
    mwcfarms No longer a newbie, moving up!
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    A picture I am going to get printed and was wondering which edit is best. Thoughts?
    [​IMG]
    and the initial edit I did
    [​IMG]
  2. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,490
    15,216
    USA
    I think the first image looks more visually interesting,and will probably be the better printed file, although it does look a wee bit "flat" to me, for a print file. (I do realize that we're looking at a greatly-reduced image on the web, and not the actual print file.)
  3. Badebolden
    Badebolden TPF Noob!
    Sep 17, 2010
    15
    Denmark
    I like the first picture the most.
    But both photos look like paintings, very cool.
  4. mwcfarms
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Flat howso. What would you adjust to make it not so flat? Sorry Im not arguing with you. I agree than this edit lacks the punch of colors in the first but Im not really sure in editting how to fix it. And I think I should fix the grain bins. I have lost a lot of the right side with the shot I didnt notice before.
  5. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    I agree with Derrel, the first one look better to me, but still looks a little flat.
    I know...'flat' isn't really a very descriptive term, and doesn't help you much.
    If I was my photo, I'd boost the saturation/vibrance, and also the contrast. But rather than using a contrast slider adjustment, I'd use levels & curves.
    I'll take a quick stab at it, if you don't mind.
  6. mwcfarms
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Not at all, just tell me how you get there. Lol.
  7. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    Ah...I see that your image has an ebbed color profile of ProPhoto RGB. You should change that to sRGB before you upload it or send it out for printing.
  8. mwcfarms
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Woops I forgot lol. I have the other on my flickr let me fix it quick.
    Should be fixed. I always forget to do this.
  9. Big Mike
    Dec 16, 2003
    33,875
    1,825
    Edmonton
    OK, here is what I came up with.
    [​IMG]
    First I created a levels adjustment layer. The histogram looked pretty good already, but I dragged the end sliders in from either end just a little bit. I think I moved the white point (right side) slider a little more.
    Then I created a Curves adjustment layer and made a slight S-curve to increase mid-range contrast. Command Primer
    Then I created a hue/saturation adjustment layer and boosted the master saturation. I also boosted the blue saturation and tweaked the hue by a point or two. I took the yellow saturation -2 down as well. I'm not working on a calibrated screen here, so take that for what it's worth.
    *edit* I maybe should have toned down the cyan, as the sky near the horizon looks really cyan...but oh well.
    I'm working on an older version of Photoshop here, otherwise I might have tried to adjust the Vibrance, which is a cool feature of the new versions. It's like saturation but also different.
    Next I used the dodge tool to lighten the barn a little bit. Then I used the burn tool to darken the edges (vignette) but also to darken the sky and other select parts of the image as I saw fit. I do this with a very low opacity and treat it like I'm freehand sketching, with many loose strokes.
    On a larger image, before printing, I might also take some time to selectively sharpen parts of the image.
  10. Derrel
    Jul 23, 2009
    40,490
    15,216
    USA
    Okay, the first image is flat...meaning local contrast is not high enough. The overall tonal range is broad, so the "total" or "overall contrast" range is fine. WHat it lacks is differentiation between the closely-related tonal values, so the phrase is that this file "needs a boost in local contrast". To do that, you could use Unsharp Masking at 10 percent, 150 Pixels, Zero threshold, and run that simple operation and literally see the degree of added contrast that I would suggest for a print file, to render the scene the way I think it would look best. One could also tweak the curves,as Big Mike suggested, but that can sometimes change things a bit too much, or not--it depends on how skillfully you adjust the curves. MY suggestion of USM at 10 percent, 150 Pixel Radius, Zero Threshold will literally show you about what I mean by flat, and what degree of local contrast enhancement I think it needs, to fit my idea of the scene's rendering via inkjet output.
  11. mwcfarms
    Mar 16, 2010
    2,656
    179
    Southern Alberta
    Thanks, I am going to go play now and see if I can get close to that playing. Will try both ways and see what I come up with.
    I havent used Levels/curves as much in PS as I have the adjustment brush in lightroom and I see now what a huge difference the US mask does to it.
  12. supraman215
    supraman215 TPF Noob!
    Oct 25, 2006
    979
    12
    Philadelphia
    Did you ever print the pano of the $250k dualie-tractor thing? I loved that pic.
