Wide Angle - Nikon (FX)
Discussion in 'Photography Equipment & Products' started by lamar328, Sep 1, 2010.
  1. lamar328
    lamar328 TPF Noob!
    Mar 10, 2008
    50
    Toronto
    Hey everyone,
    I've got a DX Nikon at the moment and looking into a nice wide-angle for it. I'm planning on upgrading to a D700 (Full-Frame) and would like to know what your experience with wide-angles on an FX camera has been. Is there vignetting, extra distortion, etc..?
    I've heard that the Nikkor 14-24 F/2.8 is nice because of its wide aperture. It seems to look fairly nice on a FX, but wondering if any wider would be a mistake? Although something wider such as a 12mm might be cool on a DX sensor, when put on an FX it might be overkill.
    Thanks
  2. MrLogic
    MrLogic TPF Noob!
    Mar 27, 2008
    423
    Rotterdam, Netherlands
    No, 12mm isn't necessarily overkill, but it is extremely wide. Sigma has a decent 12-24mm lens as I'm sure you know, which was "designed for use with full frame digital cameras."
    12-24mm F4.5-5.6 EX DG ASP HSM - Wide Angle Zoom Lenses - SigmaPhoto.com
    And yes, the 14-24 "vignettes" - like any other wide angle zoom, but you can easily correct it in DxO Optics Pro.
    [​IMG]
  3. iAstonish
    iAstonish TPF Noob!
    Feb 12, 2010
    270
    Are you looking for something ultra wide specifically? A 14-24mm is going to be a lot different on a full frame. The 24mm will basically turn into the 14, so you do the math haha
    That said people do use 8mm on crop sensors, so whether or not it is an overkill is ultimately up to you.
  4. ann
    ann No longer a newbie, moving up!
    May 14, 2007
    4,263
    189
    hm, on a full frame the 24mm is a 24mm and the 14 is a 14
  5. kundalini
    Jul 18, 2007
    13,603
    1,932
    State of Confusion
    The 14-24mm f/2.8 works wonderfully on the D700. The front element is quite bulbous, so care it needed when dangling from your lens strap to avoid bumps even though it has a permanent hood. Also, it will not accept any screw-on type filter. Lens flare is problematic if pointed towards the light source.
    This is incorrect.
  6. iAstonish
    iAstonish TPF Noob!
    Feb 12, 2010
    270
    You know what I mean, and if you didn't I meant in relation to his current crop sensor.
  7. iAstonish
    iAstonish TPF Noob!
    Feb 12, 2010
    270
    So you're saying the 14mm on a 1.6 crop factor body won't look similar to a 24mm on a full frame? Because I'm pretty sure a 14mm on a 1.6 crop would equal out to 22mm. So the 24mm on a crop sensor would equal out to what? 16mm on a full frame? For comparisons sake and the lens given, I think it was a simple way of conveying the difference for the original poster. Excuse the 2mm difference.
  8. MrLogic
    MrLogic TPF Noob!
    Mar 27, 2008
    423
    3mm, actually. :sexywink: Nikon doesn't have ~ 1.6x crop sensors like Canon does. DX ~ 1.5x crop factor.
    The equivalent field of view would be about 21-36mm on DX.
    21mm is much wider than 24mm, IMO.
  9. iAstonish
    iAstonish TPF Noob!
    Feb 12, 2010
    270
    I didn't know the crop sensors were different, thanks for the info. Yea, I agree 3mm makes a difference, but for comparison's sake, since he has the lens he could generalize it to get an idea.
  10. David Dvir
    David Dvir TPF Noob!
    Aug 31, 2010
    121
    18
    Toronto
    You won't really need much wider than 14-24. It's a really great lens. At 14, there is some barrel distortion already so any wider would be a bit too warped. I have occasionally used my 10.5 fisheye on the FX bodies for a bit of a crazy shot. But you've got to cut the hood off the fisheye in order for you to fill most of the frame since it's a DX lens.
    14-24 is definitely the way to go.
  11. ann
    May 14, 2007
    4,263
    189
    no i didn't know what you meant, as if i did i wouldn't have made a comment.
    on full frame cameras the lens are what they are, on cropped sensor they vary from 2 to 1.6 , 1.5
  12. shaunly
    shaunly TPF Noob!
    Mar 20, 2009
    575
    6
    Orange County, CA
    Do the quick math. DX sensor are 1.5X cropped. Which means on a DX sensor 50mm X 1.5 = 75mm equiv on a FX sensor. 12mm on a DX is the equiv view of 18mm on FX. So to answer your question, FX sensor is the way to go if you want true ultra wide. No DX lens has the performance of a 14-24 f/2.8, 16-35 f/4, or 17-35 f/2.8.
difference between nikon 80-200mm and 24-80mm lens
nikon fx wide
nikon fx wide angle lens
nikon fx wide angle lenses
nikon wide angle zoom fx
third party wide-angle lenses for nikon fx
wide angle for fx nikon
wide angle nikon fx
wide angle zoom fx
wideangle prime fx
