35mm speeds?
greasemonkey
Just passing through
Howdy, I am some what of a tradilist and am still shooting in 35mm black and white (t-max, but triX is alright too). I am starting to get into shooting later at night (between 10-2 or 3 in the morning) and am looking for a higher speed film, but am unable to find it at any of the local stores. Does anybody know what options I have, and where I can get the film?
By higher speed film, do you mean a high ISO film suitable for hand-holding without flash, or a low ISO film for tripod work?
T-Max 3200 is a very interesting film for low light photography, but is very very grainy. Ilford make excellent low ISO fine grain B&W films. As for where to buy them, a photographic specialist or the internet (B&H) perhaps?
Rob
Well, typically I use 400 ISO (T-max). If I want to shoot in darker conditions, I would want a higher speed film, which would be more sensitive to light, right? I do have a tripod but its not the best, and it works but thats all it does.
I'll have to check out B&H, thanks!
You can either lengthen the exposure - i.e. use a tripod, or you can up the ISO. Bear in mind that increasing the sensitivity of the film will increase the grain. I like TMax3200, but it is VERY grainy.
Rob
Try B&H and Freestyle, too - both linked from here by clicking on the banner ads at top & bottom of the page. In addition to a faster film, use the fastest lens you have, as well. A lot of times just having that combination, with a tripod, will be enough for low light conditions.
There is Kodak Tmax P3200, Ilford Delta 3200, and Fuji 1600. None of these are actually as fast as the label says; they are all closer to ISO 800, but they are designed to be pushed. My results with all three have been fairly coarse grain; for some subjects it works, but usually I prefer something a little finer. There are all sorts of ways to get more speed out of most of the ISO 400 films too. I'm a big fan of Tri-X 400 at ISO 1250 developed in Diafine.
ISO 3200 is only 3 stops faster than ISO 400. Depending on the lighting conditions you are encountering you may still want to use a tripod. If your exposure is 1 sec at ISO 400, you'll only get up to 1/8th sec at ISO 3200.
I am a big fan of Fuji Neopan 1600. I haven't tried any other high-speed films, but I know I really like this one (as well as the 400ISO version).
The best thing to use for shots late at night is a tripod, though. Even 1600 speed will be hard to use handheld outside in the middle of the night.
For night photography you'll need to pull out the tripod, guaranteed.
Like what sort of ways?
Thanks everybody, it looks like I'll have to stick with my tripod...
