Dao
Typically, on today's cameras, the 50mm lens will give you a smaller field of view than it might have with film cameras....something along the lines of what an 80mm lens would have.. This means that your landscaped will reflect that difference.
I believe you're refering to crop sensor frames, and in that case it only applies if the lens was designed for a full frame sensor and you're sticking on a crop frame body. If the lens was designed for a crop frame (like Canon's EF-S lenses, say on a 40D or Rebel) then there is no crop factor, and thus the FoV is the same at equal focal lengths on a full frame body with lenses designed for full frame sensors (say, and EF lens on a 1D).
hum...
EF-S 17-55mm lens at 17mm on 40D vs EF 17-40mm lens at 17mm on 5D.
Even both are at 17mm, but the field of view are different.
So, it does not matter if the lens is designed for cropped sensor body or not. 50mm focal length, whether it is EF or EF-S, the field of view are different when mounted to a cropped body then mounted to a full frame body/film body.
