A Drop of Water
Amazing!! It's good that u cropped it as you want to emphasize the water...not the cup. Next time, try to due the water to add some colour. Or maybe even some flashes!
You captured the movement nicely! PP is right about the crop, good decision on that.
I am assuming you used onboard flash by the bright spot on the glass. Research some different lighting techniques and see what you can come up with.
Actually used on flash + slave wireless. Should have moved the slave further back & reduced the output of on-camera flash.
Thanks.
