Scuba
- Joined
- Dec 8, 2009
- Messages
- 853
- Reaction score
- 65
- Location
- Cincinnati
- Can others edit my Photos
- Photos OK to edit
I like sunsets. These seem to lack composition. Most of my "WOW" sunsets were taken AFTER the sun set.
Thank you for your feedback. How would you suggest to make the composition better on these if possible?
I will have to try the after the sun has set.
MLeeK i guess thank you first. When you say over done can you be more specific? These are only lightly edited. You say the first one has amazing potential again can you explain. The piers are what is sticking out of the water, however I don't know how to make them anything but silhouettes being that they are back lit by a sunset. Do you have a suggestion? I tried a shot or two with my flash but it didn't help. The only other way I can think of would be to use a graduated ND filter or do an HDR.
I think if they weren't so underexposed the pier silhouettes would look fine as silhouettes. As it is they are there is no telling where the reflection begins and the pier ends, they are just one solid black spot. You want to try to have a little detail. Even the skies are underexposed so increasing exposure wouldn't have hurt you any. The saturation on the oranges is what is a bit over the top.
With a landscape you don't want your sun to be dead center or your horizon line to be dead center. You've done pretty fair here. The movement in the clouds helps your composition a bit. Your far side trees also blend and there is no telling where the reflection begins or ends. A full stop higher on the exposure would have kept them still a silhouette, but given you some more visual interest instead of great expanses of solid black that won't look very great in print.
