H4X1MA
- Joined
- Aug 10, 2011
- Messages
- 327
- Reaction score
- 59
- Location
- Vermont
- Can others edit my Photos
- Photos OK to edit
I know that these 3 things are a major part of taking good pictures, but for some reason my mind is not wrapping around them. I think that most of the articles I read are too technical. It's nice to know why something does what it does, but I need to know HOW to make it work.
White Balance: I think this is one of my main weak spots, and it may always be a weak spot since I am colorblind to greens and browns. I read through the tutorial on Cambridgeincolour.com but it still didn't say how you actually achieve a good balance (at least in a way that made sense to me). From what I gather you select something in the scene that is prodominent in the scene, then adjust your color slider to that color?
Metering: This is a complete mystery to me, even after reading about it. Can someone dumb it down and explain how it is physically done?
What i gather, metering uses the highest white points and the darkest dark point to determine what the exposure should be. So if you spot meter a dark object with almost no white, then you will have a dark pic and vica versa. But what I think doesn't make sense or else I would think that manual camera modes would remove this option since exposure is more controlled by the shutter.
Circle of Confusion vs Depth of Focus: The article I read says that these are not the same, but it doesn't make sense on how they are not. CoC basically says that you lose focus after a certain point and objects start to get blurry, but isn't that the same thing that the DoF does? is CoC just a "scientific" explanation of what happens on a mostly non-visible level? What am I missing here.
