advance print menu gone in ps
denada
hi. it used to be that if i clicked printer settings i would get more options. now it looks like this ...
anyone know what happened to all the options like color mode and output resolution?
thanks!
Under *Printer* are you sure you've installed and selected the EPSON printer driver and not the default Apple one?
thanks.
i installed stuff from epson's website and now i get the full menu when i pick "sc-p600 2," which did not previously exist. it get rid of adobe rgb (1998) as one of my profile options. that had been the one i was using. i picked the paper type instead from the menu above the line and i don't think i can tell much of a difference.
should everything be 360 or 720 dpi with this printer? if you can't quite get 720 should you go from 650 dpi to 360?
thanks
To be honest, especially with the resolution of modern printers, I really don't think it matters. I don't see any issue with any of my prints from a SC-P800 and I always specify the size I want in mm not dpi.
