Dave Colangelo
- Joined
- Apr 27, 2016
- Messages
- 452
- Reaction score
- 159
- Can others edit my Photos
- Photos NOT OK to edit
It does. Go into menu and you will see TTL, change it to manual and select the power. I use on my onboard flash this way outside a lot, even with CPU lens. Great for flash fill. @Derrel posted a link some time ago to using your onboard flash, works great in certain situations.I don't think the flash will work with the manual lenses on the 3300 (at least it does not on mine but there may be a setting I don't know about). however I have never needed it when taking bird photos (I typically go out during the day). If I really need a flash (although its only good under 1/125) I have an old Sunpak I found at a flea market, for $5 it does a bang up job when I need it to. I am a big fan of using the older glass on the newer cameras when it comes to being on a budget. Along with the 300mm I found a 50mm 1.2 AI-S at the same antique store for quite a deal...
Sent from my XT1254 using Tapatalk[/QUOTE]
Thanks for the info! Ill give it a shot when I get home!
