It's little more than a cheap telescope. It's pretty much useless.
Try to sell it on eBay if you can.
Ehhh... I don't think that's totally fair. The IQ isn't up to a 600mm prime to be sure, BUT those are pretty good bang for the buck, and if you want a LONG reach and aren't a pixel peeper, it's a good way to get it.
As others have said, these are 100% manual lenses. Here's how to make it work:
1. Put the kit lens on your camera, set the camera to 'Manual' and meter the scene you want, ensuring that your shutter speed is as high as you can get it (You have to mount this on a tripod, it is NOT a hand-holding lens).
2. Note the aperture and shutter speed, then remove the kit lens, put on your new toy, and manually set the aperture on the ring at the rear of the lens, and ensure your shutter speed is correct. Mount the lens/body on your tripod and shoot (pref. using cable/remote release).
3. Check the results on your LCD and adjust exposure as necessary. In preference to changing lenses, you may simply want to mount your Rokinon and then use the
Sunny 16 rule as your exposure starting point.
