Balwazer
- Joined
- Nov 15, 2010
- Messages
- 31
- Reaction score
- 0
- Location
- Bahrain
- Can others edit my Photos
- Photos NOT OK to edit
Hi all,
It is my first time in your forum and hope I give knowledge as much as I take.
Well, I do advertising photography, but I am having problem in freezing the shots while there is an ambient light in location.
For example the last assignment I have it was in the airport I was shooting the model against large windows. So I needed the ambient light to make the photo natural. I also used two strobes to fill the shadows.
I got away from it doing the following:
I used shutter speed: 1/100sec, F5.6, ISO 400 for the most shots
The results ended slightly noisy and most photos had a shake on them. But for the non movement photos they were perfect except the noise which fixed in lightroom easy.
The problem is:
1- I couldnt go above 1/100sec because I will lose the ambient light
2- Couldnt raise the strobes power for the same reason
3- Couldnt raise the ISO because of the noise
So what would you do if you were me? To freeze the action while needing both the ambient light and the strobes light?!!
The problem is:
