KenC
- Joined
- Jan 18, 2010
- Messages
- 5,699
- Reaction score
- 1,472
- Location
- Philadelphia
- Can others edit my Photos
- Photos NOT OK to edit
Why so much concern about the borders on an 8 1/2 x 11 piece of media? What's important is how you intend to show your work - if in a mat/frame, then the mat will be cut evenly to show the image, if electronically, then you can put an even black (or any other) border around the image. Another concern touched on by others above, but perhaps lost in the calculations, is that if you do crop your image to get even borders on a page, then you may be presenting the image in a less than ideal aspect ratio and/or composition, which is something to avoid. I've seen people fall into this trap when they want to use a standard size pre-cut mat or mounting board - all of their images are always cropped the same way to accommodate that, and for some of the images it is obvious that the composition is not good.
