adamhiram
- Joined
- Feb 6, 2015
- Messages
- 879
- Reaction score
- 598
- Can others edit my Photos
- Photos OK to edit
I have always been intrigued by the idea of simulating golden hour with a gelled strobe, and my wife was kind enough to assist. It seems like whenever I scout a good location for natural light family photos, either the timing is off, the weather doesn't cooperate, or the sun is coming from the wrong direction. Having the ability to put the sun where I want it and shoot when it is convenient for me or the subjects comes with many advantages, as well as its own challenges.
I am primarily looking for feedback on the lighting, but any CC is appreciated.
Examples & tutorials
#1 Strobe out of frame, camera left
I think this setup provided the most pleasing light, creating a nice wash of orange across both the background and wrapping around the subject's face.
20210605-DSC_3353a by adamhiram, on Flickr
#2 Strobe directly behind subject
This provided a nice backlight look, but left the subject's face in complete shadow. With this much ambient light, it was easy enough to lift the shadows for a correct exposure, but I think this is where some subtle front fill would have been a nice touch, either from a reflector or 2nd strobe. Also worth noting, you can clearly see the line in the background where the orange wash starts in front of the strobe, even at 75' away. I think for this technique to work, there needs to be a definitive background element that is illuminated by the strobe in order to include any background in the shot, otherwise it will always be missing the color cast behind the strobe.
20210605-DSC_3372a by adamhiram, on Flickr
#3 Strobe in frame
I have mixed feelings about this setup. Ultimately I like the results, but I expected a lot more lens flare from the bare bulb flash being in the frame. I'm curious what others think of the light placement here, and if it would be better off elsewhere in the frame or just kept out of the frame entirely.
20210605-DSC_3414a by adamhiram, on Flickr
Thank you very much for any feedback!
- Pye Jirsa had one of the best tutorials I have seen on this, which can be found here (and here). He provides a great technical explanation of adding an orange glow using a double CTO gel, and placing the light far enough away that it appears to be in the same place as you would expect to see the actual sun, and casts an orange wash over the entire scene, not just the subject. The main challenge I had in following his example is he missed golden hour and was shooting at dusk when it's easy enough to shoot wide open and add flash without overexposing. I was hoping for something I could use in open shade or on an overcast day.
- Vanessa Joy had a similar tutorial here that explained many of the same concepts, but she moved the strobe off to the side to better illuminate the background. I found this quite helpful, as no matter how far back I moved the strobe behind the subject, eventually there would still be open space behind the strobe that did not have an orange cast on it.
- Mark Wallace had a tutorial here where he did the same thing in bright direct sunlight. My main take-away here was how to get my shutter speed down to 1/200 in order to use a strobe without exceeding the maximum sync speed. He used a variable ND filter, while I figured it would be easy enough to just use HSS. It cost me 2/3 of a stop of light, which is better than the 2 stop ND filter I would have needed in midday sun.
- Ambient exposure and shutter speed: My first challenge was getting the shutter speed down to 1/200 while shooting wide open so I could add strobe without overexposing. At ISO 100, I was looking at 1/800s for correct exposure in open shade on a sunny day, 1/500s on a cloudy day, and still 1/320s in completely overcast conditions. Shooting at 135mm I could certainly close down the aperture a bit to get an extra stop of shutter speed, and there is a "Lo" ISO setting that effectively shoots at ISO 50, so I had some room to work with. HSS was another option, assuming I had enough flash power (I did). Ultimately, the shaded location I used allowed me to shoot wide open at 1/200s at ISO 100 and be slightly underexposed, which was pretty ideal.
- Location: I returned to a favorite park with a wooden arch bridge over a stream next to a lake. I have shot here in the fall and it is always in full shade, making it easy to work with. However, apparently in the summer the sun is higher in the sky and that bridge is in full or dappled sun. Fortunately, there was a lot of open space next to the lake that was in pretty deep shade under a canopy of parallel trees that framed the subject nicely.
- Lighting: I used a Flashpoint Xplor 400Pro strobe with the stock 4" reflector and a double CTO gel, fired at full power. I placed the light about 75' behind the subject, and moved it around, from directly behind the subject, to in the frame next to the subject, to fully out of the frame just off to the side.
- Lens flare: Or lack thereof. I never thought I would be able to put a 400Ws bare bulb strobe firing at full power directly at the camera in the frame and not get any lens flare. Nikon's Z lenses have such little flare that I decided to switch to my Sigma 135mm just to add some. I still wasn't able to get it to flare in most shots, which would be a good thing any other time!
- Fill light: I did NOT use a fill light, but I toyed with the idea of increasing shutter speed to darken the frame overall, and adding a front fill (key?) light to illuminate the subject's face. I will experiment with that some other time, but I came across some great examples here (loop lighting from softbox) and here (on-axis fill from on camera flash) that here that produced very pleasing results.
- Settings: These were shot on a Z6II and Sigma 135mm f/1.8 lens at 135mm, f/1.8, 1/200s, ISO 100.
#3 Strobe in frame
