Beseler 23CII vs 67S???
j0n
Anyone have any experience with both of these enlargers? Can you tell me what the differences are and which you would prefer given the choice? Thanks!
The 67 series is basically a larger version of the Printmaker 35. It's a single column enlarger that'll handle up to 6x7cm negs. The 23C series is a twin girder enlarger, and is considered a step up from the 67 series. There are a wider variety of accessories, and it'll handle up to 6x9cm negs.
Which is better in real life probably depends on condition, and what accessories come with them.
I use a 23C II. It's sturdier than the 67 series.
The 23-series will also print up to a 6x9 negative while the 67 will do
up to 6x7.
You can also tilt the head on a 23 and project onto a wall for huge prints
if you have the need or desire to do that. I don't think the 67 will do that
but I could be mistaken.
Negative holders and lens boards are also much easier to find for the
23-series enlargers and in more variety.
But, the 67 is lighter and more compact if that is important to you.
this is a 67 correct? Will a negative carrier for a 23cII work in it?
^ Yes, it looks like a Beseler 67.
Neg. carriers and lens boards are not interchangeable between the 67-series
and 23-series enlargers.
BTW, there's nothing wrong with the 67. If you found a good deal on one,
I would seriously consider it.
Thanks for the assistance... I picked that one up last night for a real good deal IMO.
