sneakypete
- Joined
- Jan 30, 2015
- Messages
- 35
- Reaction score
- 9
- Can others edit my Photos
- Photos OK to edit
I have the lx100. :shrug:
Yes A7 is a very good camera and more importantly its a full frame mirrorless and just for that its already groundbreaking but it does have few things you should rememberI'm saving up for a Sony A7! I've heard so many good things and I got play with one the other day and it's amazing![]()
Auto Focus system is not as good as a matching DSLR
Very, very poor lens selection
If and when Sony will come out with good fast lenses they will be just as big, heavy and bulky as a full frame DSLR lenses.
Yes, there are adapters but in most cases you will need to manually focus as they will not auto focus with the adapter.Yes A7 is a very good camera and more importantly its a full frame mirrorless and just for that its already groundbreaking but it does have few things you should rememberI'm saving up for a Sony A7! I've heard so many good things and I got play with one the other day and it's amazing![]()
Can't you get an adapter to put your DSLR lenses on the A7? But then again, what's the point? Might as well just get a DSLR.
There are so many choices today and choosing between them can be tricky, very tricky.Nealman-
If you're looking for a do-it-all type of camera in a small package for travel ... Don't overlook the Fuji X cameras. The X-T1 is similarly sized as the EM1 and the A7 but uses an APS-C sensor ... so a much larger sensor than MFT and much smaller lenses than FF. (Or, the glass is half empty approach, smaller sensor than FF and bigger lenses than MFT.) I've played with the A7 and A7S and while they are amazing to get a FF in such a small package ... they just didn't seem as solid as the Fuji's or Oly's. Fuji doesn't have as large a system as MFT but it has many more lenses than Sony. The Fuji is mirrorless, so all the pluses of legacy glass and negatives of the AF is unable to track. The Fuji lenses and solid, well built lenses that are, at a minimum, as sharp as my 'L' glass. Fuji has wonderful high ISO capabilities.
If you're in LA, we can meet if you want to try the EM1/XT1/XE2/and maybe I can bring an A7s.
Gary
Then there no need to listen to the rubbish about lenses I use the Voigtlander close focus M adapter to use my Leica M fit lenses which makes it very fast to focus and makes the A7 smallI actually almost never use auto focus.. I've always used manual!
I cant believe it but for the first time EVER I agree with my VERY good friend "gsgary", if you MF then the A7 is a good camera, just get a prime lens and get the A7, it has an awesome sensor, got same sensor on my D750, its just an amazing performer!!!Then there no need to listen to the rubbish about lenses I use the Voigtlander close focus M adapter to use my Leica M fit lenses which makes it very fast to focus and makes the A7 smallI actually almost never use auto focus.. I've always used manual!
