Solarflare
- Joined
- May 24, 2012
- Messages
- 2,903
- Reaction score
- 395
Re-read my posting. I already said that large format lenses need a central shutter. You even QUOTED it. I made it RED, BOLD and UNDERLINED so its not possible to miss it.Your 300mm normal lens for [approx] 200x250mm [aka 8x10 inch, and thats ignoring the fact you probably have a lot more room than that for the camera movements] is probably f/5.6, that "nifty fifty" is f/1.8 and its a lens for DSLRs, which means a lot of things change (no need for a central shutter, need for the ability to focus, autofocus motor, etc).
Plus of course the 50mm f1.8, at least on my Nikon, is a VERY small lens. Much smaller than its housing.
My lens also includes it's own shutter though, remove the shutter and it's even smaller![]()
My point was that this comparison was completely invalid. And again - the actual optics of a 50mm f1.8 for DSLRs are quite a lot smaller compared to the size of the whole lens. Something you gleefully ignored AGAIN.That was my point.
Step back a moment and think about this LOGICALLY instead of trying to come up with flawed comparisons.
1. Lets take two sensors of any size, but one is twice as tall as the other, with any but an identical aspect ratio, so the image circle is exactly twice as large in diameter (or radius) as well. Each of the two sensors also have a lens which should give them the same focal length equivalent, at the same aperture. Question: does the larger sensor need a different lens formula, because its larger ? Answer is no, of course not. Especially the optics of the bigger sensor do not suddenly magically get smaller. They grow the same as the sensor.
2. So how heavy are the two optics ? Thats easy too: the bigger sensor is twice as tall/has twice the diameter of the image circle (1 dimension), thus the sensor area is 4 times as large (2 dimension) AND THE OPTICS WEIGHT 8 TIMES AS MUCH (since that grows in 3 dimensions).
There. Thats why, if you do the SAME optics, the weight of the optics increase. In fact, they increase at quite large speed indeed.
