biggest baddest EHD
paigew
Texas (Hill Country)
I need it. Tell me your faves. I need to remove a bunch of files from my hd asap!!
If by EHD you mean an external, then there's a couple things to consider...
-storage size
-portability
-price
-file safety
If you have the budget for it ($400 or $500 to drop), I recommend going with a Synology NAS. Robust, accessible from every computer within the network (and outside the network if you set that up), and has expandable storage slots. It's essentially a mini file server.
I bought a Seagate 1TB last cyber monday. Got it for a good deal and it's worked well.
I've got a couple Seagate's also.. has been fine for me.
thanks guys! Yes safety and storage size are big factors. And speed...are some faster than others? I found some on amazon with good reviews, but I always like asking "real" people :P
I picked up 2 Seagate 3T about a year ago.....one is still working fine, the other died within 5 months......
On the other hand, I had a WD 5G that worked fine for about 6 years.....
If all you're worried about is someone from the outside accessing your data, the "safest" is going to be keeping all your data on an external that can't be accessed through an IP.
If you're worried about HDD corruption, then keeping your data on a fileserver in a non RAID0 config is going to be the best bet.
If you're worried about losing files, back everything up twice (once on a server, once on an archived separate external), and keep a working copy on your computer.
And currently, 5400 RPM drives are the slowest, but extremely cheap, which makes them popular for long term storage and archive drives. 7200RPM ddrives are significantly faster and not that much more expensive. 15000 RPM drives are primarily used on servers, and are purchased at a premium, and it makes no sense to buy them when you could just get a SSD (solid state drive) for a little more and have better speed, performance, and stability.
I deal with bulk data storage for work (storing PPI), and what tends to be the best practice is when you capture a file on your computer, duplicate one copy to a working directory, and one as the "clean" version to the file server. Then back up your file server weekly, monthly or not at all (depends on whether or not you feel the need to do so). Thus when you cleanse your working directory after it gets too large, you have the files backed up on the fileserver, and possibly on an external backup if you don't trust the longevity of the server.
I have a Western, so far so good; I've heard Seagate is good too. Got mine from Adorama.
I've got a Drobo 5N that's been reliable for the year+ I've had it. It maxes out at 16TB w/ 4TB drives, though, if that matters to you.
this is what i have you get 2tb for about 80 bucks and that seems like a heck of a deal, i have had mine for a few years. i cant remember if i got the 1tb or 2tb version i cant imagine most people would actually need more than 1 or 2 tb. i actually like to have 2 external hard drives, that way if one happens to die than you have a second copy.
http://www.amazon.com/Seagate-FreeA...&sr=1-3&keywords=see+gate+external+hard+drive
