- Joined
- Jun 25, 2016
- Messages
- 688
- Reaction score
- 783
- Can others edit my Photos
- Photos OK to edit
How does that work?Awesome shots, but wish you'd embed them instead of linking.
A 6dNice shots, what lens filter are you using?
a 17-40 f4
and a Tiffen CP
also are all CPs equal or do you get what ya pay for?
a 17-40 f4
and a Tiffen CP
I would agree with that, that is probably true in a lot of cases when the differences hardly vary, *which would most likely make it a good lens for it's price but if it has a 'prominent' negative effect that jumps out at you, like making everything look brownish or way too dark it should be obvious at a glance that without a doubt, it's inferior.You can spend a bloody lot of money on filters. As I am not a professional photographer I can't justify the price. I have been buying "Gobe" brand filters which are not to expensive and seem to give a good result. Then again unless you capture an image using the cheaper filter and then immediately use a more expensive filter and compare the images you probably won't known the difference.
Sent from my SM-G965F using Tapatalk
You absolutely, 110% get what you pay for! Like a lot of things, the difference will be minimal in a majority of applications, however in circumstances such as shooting UWA, or into the sun, a B+W, Heliopan, or similar will show its worth compared to a $50 MiC piece of junk.also are all CPs equal or do you get what ya pay for?
