I would rate is as "ewwwww." Lots of chromatic aberration visible as green fringes around out of focus highlights....the out of focus areas in the foreground look awful...
Thanks. I wouldn't have mentioned it if it wasn't for the press release of the 35 f/1.4:
"A woman is sitting at the bar of a dimly-lit cafe. Lost in thoughts, she doesnt notice the glass of wine the bartender places before her. From a distance, a photographer tries to capture her mood. He brings her face, which is leaning toward her phone, into focus. Everything around her becomes a blur, and the lights in the background coalesce into a wild dance of diffuse shapes.
This shot will only work with a fast lens with short focal length and harmonious bokeh. Carl Zeiss introduces a new lens for just such images: the Distagon T* 1,4/35.
By introducing the Distagon T* 1,4/35, Carl Zeiss is complementing the Planar T*1,4/50 and T*1,4/85 lenses with a wide-angle lens that shares the same high speed. Crisp, sharp images work every time, whether at dusk or in the weak lighting conditions of a café, and without the need for a tripod. With its 35-mm, the Distagon T* 1,4/35 matches the classic and versatile standard focal lengths when used on cameras with APS-C sensor formats.
Due to the special bokeh effects in both the foreground and background areas, the Distagon T*1,4/35 opens up new creative possibilities, giving photographers more options to play with focus. Thanks to its large focus ring, photographers can also create highly accurate, sharp pictures, even at maximum aperture opening. In addition, the optical construction of the lens guarantees high image quality across the entire image range. Furthermore, with one step less than the full aperture opening, the light fall-off toward the edges is just one f-stop.
With the ZEISS T*s anti-reflective coating, its sophisticated stray light reduction and the excellent flare control the new Distagon also takes pictures of bright light sources without artifacts. The Distagon T*1,4/35s extremely long-lasting and robust all-metal precision mechanics, for which Carl Zeiss is known, make this lens perfect for use on-the-go and for photo reports.
The Distagon T* 1,4/35 will be available in first quarter of 2011 at a recommended retail price of 1385.71 (excluding VAT)*."
:er:
Carl Zeiss Press Release: Distagon T* 1,4/35
