CobraMisfit
- Joined
- Jan 12, 2012
- Messages
- 8
- Reaction score
- 1
- Location
- Virginia
- Can others edit my Photos
- Photos OK to edit
Macro Enthusiasts,
Im new to the photography world and am focused on learning the basics at the moment, but Id like to graduate into macro down the road. I currently have a D5100 with several okay lenses, including a macro, that I got at a great price due to the local shop going out of business. Having read through a lot of back pages on the Equipment and Macro sub-forums, Im realizing that I have no idea what Im doing and could use some advice. Specifically, my macro interests are insects (my wife and I are beekeepers and want to get some good close-ups of the girls).
Based on other threads, it seems that I might need the following (please correct me if Im off-base):
1) Better lens: Im currently using the Tamron 60mm f/2 1:1 SP Di II, but I have my eye on something like the Tamron 90mm, Nikon 105mm, Tamron 180mm, or Tokina 100mm. According to past threads, a little more distance is preferable when shooting insects and I assume 60mm will be too close.
2) Flash: Since I dont have one, it seems better to get a normal, high quality one first for utility. Perhaps the SB-700 or higher. Secondary would be a ring flash. Either the Phoenix or Sigma EM-140.
3) Extension Tubes: I have the Kenko on my Wish List, but it sounds like it might not be as effective on my 60mm as it would be on something 90mm or higher.
4) Teleconverter: This is a bit confusing and intimidating since it sounds like there are a lot of compatibility issues, but it seems that the results are very good. As someone starting out, Im not sure if this is right for me at the moment. Tamron has a couple, but if I upgrade, would I need the appropriate teleconverter for that lens (i.e. Nikon for Nikon, Tamron for Tamron, etc)? Even then, Id need to ensure its compatible, right? Also, is this a case where more magnification is better (1.4 vs. 2)?
5) Tripod: I think the 190X with the Manfrotto 410 Junior head might be the right starting point.
Apologies if this is a repeat discussion, but I wanted to check with the experts before spending any more money. I appreciate the input.
