C&C on outdoor Family Session
jenniferrose
I think you've captured some nice expressions. Well exposed. The cropping seems a bit awkward. Not enough room above them in the family shots. On the individual shots, to me, they are not close in enough to justify missing parts of their heads....seems either too tight, or not tight enough. Hope this helps.
Desi
cropping is definitely awkward... Why did you make it that way? yes, I mean, in every picture
C&C per req:
1. This image should probably be consigned to the circular file. On the plus side, well done you for actually using your flash to provide fill light; without it this would have been a total mess, unfortunately, it was direct, on-camera flash, and not nearly strong enough. The exposure on the faces isn't bad, but you needed a LOT more light to knock down the ambient and bring some detail into the nearly blown sky. As well, WHY were you shooting portraits at 18mm???????? WHY?????? Unless you're shooting a larger group (5-6 adults minimum) 70mm should be your minimum focal length to avoid distortion. Additionally, because you chose such a short focal length, everything is in focus... the background is NOT what we care about, and separating the subject from the background with selective focus is one of the key methods for ensuring that the eye is drawn to the right part of the image. In this one, my eye does not know where to look.
2. Great moment! I love the expressions here, even if their eyes are are a bit 'squinty', but... their faces are soft. Again, selective focus would have helped a lot here. If you don't have a longer lens, I would highly recommend getting one, even the 55-200 when racked out to 200mm will help. I would try and remove the white pole image left and up the exposure on their faces a bit as well as a slight contrast boost; it's very mid-tone rich.
3. Nice expression, and consider yourself VERY lucky to get a smile like that from a girl her age wearing braces! Well done. The eyes are a bit dark however, and fill light would have really helped her. As others have said, what's with this crop????? It makes no sense to me at all.
4. A nice, natural expression, but again, fill light was desparately needed, and your background choice here was NOT ideal. The human eye is naturally drawn to bright areas over dark, so I'm immediately pulled from her face to the bright, white flowers behind her. Again, a long focal length and large aperture would have helped eliminate this issue.
Overall, they're not a bad set, but you need to review some basics: Long focal lengths are your friend. Be cognizant of backgrounds and choose those which are even and homogenous, ideally shooting and lighting to have your background at least 1/3 stop below the facial skin, and remember, whenever you think you don't need fill light, you probably do. Last, but not least, the hot shoe on your camera is NOT a place to put a speedlight, rather it's where you put your trigger to fire your remote speedlight, and pop-up flashes are evil. Pure. Evil. They should be avoided at all costs!!!!!
Just my $00.02 worth - YMMV
~John
I'll just go to Derrel's favorite: Fill Flash!
She has dark eye sockets - raccoon eyes - and the area around her mouth is also dark.
Be mindful of the direction and the quality of the light you use.
If you want to use high side light or back light you need to use fill or accent light from a reflector or from a flash unit.
Off camera flash (OCF) delivers more pleasing light than a flash on the camera will, but technically fill light is on the lens axis.
Even if you use available light the fundamentals of photographic lighting still apply if your goal is to make high quality photographs.
I really enjoy the fact that the expressions in the photos seem entirely genuine...When taking portraits one can come across many photos where smiles look too fake, but in these photos it is believable. However, I agree with the general consensus that the cropping is awkward.
To clarify: it's derrels favorite response to hate on.
I thought that was my favorite.... :(
Well I thought it was Derrel's favorite and that Derrel was your favorite.. so ipso facto..
Arggh.. ok, can somebody put this stuff in a chart? It's really getting confusing.. lol
