- Joined
- Apr 9, 2009
- Messages
- 41,401
- Reaction score
- 5,706
- Location
- Iowa
- Can others edit my Photos
- Photos OK to edit
Investigate the advantages/disadvantages of having image stabilisation (IS) in the camera body, compared to having IS in the lens.
From http://en.wikipedia.org/wiki/Image_stabilization
One of the primary disadvantages of moving the image sensor itself is that the image projected to the viewfinder is not stabilized. However, this is not an issue on cameras that use an electronic viewfinder (EVF), since the image projected on that viewfinder is taken from the image sensor itself. Similarly, the image projected to a phase-detection autofocus system, if used, is not stabilized.
In-body image stabilization requires the lens to have a larger output image circle because the sensor is moved during exposure and thus uses a larger part of the image. Compared to lens movements in optical image stabilisation systems the sensor movements are quite large, so the effectiveness is limited by the maximum range of sensor movement, where a typical modern optically stabilised lens has greater freedom.
