Can I change the ISO in RAW?
RebelTasha
Canada
I just took my first picture in RAW I couldn't find anywhere to change the ISO..
:meh:
That would not be possible im affraid. ISO is basically how sensitive your cameras sensor is to light when taking a photo.
yeah ISO is pretty much the only thing you can't change in RAW I believe
My other question would be if I wanted to change them into jpeg when I come to save them it asks
Compression Ratio
1-4 4 being highest quality
and pixels which is preset at 180 pixels/inch
If I wanted to save the images so that they are 3456x2304 which is the L with the smooth semi circle not the stepped one... (Great terminolagy)..lol
What would I use I'm assuming highest quality but what about the pixels do I leave them at 180?
Thankyou I'm not sure if I can convert myself to RAW but it seems like a great idea.
The others are right, you can't change the iso in Camera Raw. You can change the exposure though and by a fair amount, so that may serve the same purpose for you.
When I save a file as a jpeg in camera raw, I can save up to a level of 10. If I save it in photoshop, I can save up to level 12. What version of camera raw are you using?
I believe you set you default resolution (pixels per inch) in Adobe Bridge and Photoshop. This affects the image size when it is viewed in the software.
I'm using Zoombrowser I have another one on my desktop that was on the CD as well called Digital Photo Prof. I will take a look at that ..
I want level 10 too.. hmmff
If you're printing these in any way, you want 300 pixels per inch.
Ok I tried the Digital Photo software and it has the option to 10 and it says it's 350 pixel per inch for the quality I wanted.. so nicfargo thanks because I do print all the pictures I like.
Glad I have that sorted out it seems like a great tool I think i'm sold on it..
I'm so glad it has rained this last week instead of blowing a bunch of shots I've really had the time to read up a ton and now I can do RAW I'm ready to take on a subject.. lol
I'm posting my first RAW image that I just did with the Digital Photo in the "Squares" photo assignment for this week.. http://thephotoforum.com/forum/showthread.php?t=118953
DPP and Zoombrowser will serve you well Tasha. It's all I use for my RAW conversion if you need some help, yell. I would leave it at the default 350. Good shot of the squares.
Huh? What's this about not being able to change the ISO when you are shooting raw? I can do it just fine.
I save mine as 12 in Camera RAW just like in Ps. Just type in the number 12 into the box manually. It will then remember your setting as 12 "Maximum" instead of 10.
